how an airplane decollate technique
Discussion in 'Rules and Regulations / Flight Safety / Better Pil' started by kondordv, Feb 8, 2007.
  1. Feb 8, 2007 #1
    kondordv
    kondordv
    kondordv
    Feb 8, 2007
    0
    Timisoara, Romania
    Hi all,
    real pilots or virtual pilots, something is not very clear for me in flying if someone can explain to me I'll be very happy.
    Let me explain to you. In decollating an airplane runs with high speed. At the moment when the airplane leave the land what happen? The airplaine is climbing because the flaps are activated and the air direction is changed? Or the airplane is climbing because the portant force (appeared from air pressure difference)? If there is the portant force as phisics say it, is it someone to tell me how we calculate this force and what speed it is necessary to lift an airplane of 100 kg?
    thank you all,
    Kondordv:depressed
  2. Feb 9, 2007 #2
    Craig
    Craig
    Craig
    Jan 30, 2003
    543
    0
    Jupiter, Florida
    When taking off, the airplane accelerates. As the speed through the air increases, the air over and under the wing begins to create lift. When enough lift has been generated, the airplane flys.
    Lift speeds change with differently shaped airfoils.
    And yes, moving the 'flap' - meaning the moveable horizontal control surface at the back better known as the 'elevator' - changes the pitch attitude of the aircraft. The rudder controls 'yaw' - the sideways motion of the nose, and the 'ailerons' on the wingtips control motion around the longitudinal axis.
    That's about as simple as I can put it. And no, I can't calculate lift on a 100 kg airplane.
    What country are you from?
  3. Feb 9, 2007 #3
    orion
    orion
    orion
    Mar 3, 2003
    5,800
    135
    Western Washington
    First, what do you mean by "decollate" - no such word associated with airplane design.
    As far as calculating the speed for lifting a 100kg airplane, that is sort of a meaningless question since you'd have to define several variables before such an effort could be meaningful. And no, airplanes do not need wing flaps to take-off.
    To do this you must define the airplane, select a specific airfoil and wing loading, which in turn is used to define the wing area. All this then has to be somewhat optimized for available power, desired operating envelope, payload, etc. Generally, designing an airplane or providing you with the process is really beyond the scope of this type of discussion board.
  4. Feb 9, 2007 #4
    Norman
    Norman
    Norman
    Nov 29, 2003
    2,880
    919
    Grand Junction, Colorado
    Hi, Kondordv
    I think what you are looking for is the "coefficient of lift" cl for short . To calculate how much weight a certain size wing will carry at a certain speed you would look up the cl for that wing at it's best glide angle and use it in this formula:
    L= 1/2 x p x V^2 x S x cl
    Where:
    L is lift
    p (greek letter Rho) is 1.225 kg/m^3
    V is velocity in meters per second
    S is wing area in square meters
    Notice that speed (V) is squared in the formula. Say that you have a 1 square meter wing that can fly straight and level at 100 km/h with 10 kg. The same wing can carry 40 kg at 200 km/h
  5. Feb 12, 2007 #5
    Midniteoyl
    Midniteoyl
    Midniteoyl
    Sep 4, 2003
    2,406
    500
    Indiana
    Bill, sounds like he used a site like 'babblefish' to translate... not very accurate.
  6. Feb 28, 2007 #6
    Super Moderator Staff Member
    Oct 19, 2003
    5,983
    3,236
    I think I understand the question - the translation did not work into aviation english very well. I hope that our responses work better...
    Lift is a function of several things:
    Lift = (air density/2)*air velocity^2*wing area* wing coefficient of lift
    Lift increases as the airplane speed increases
    The wing coefficient of lift (Cl) is a function of wing angle of attack. For symetric airfoils, at zero angle of attack you have zero Cl. Increase the nose up attitude, the angle of attack increases, and so does the Cl and the Lift. At high speed, very little angle of attack is necessary. At takeoff speed, the nose has to be fairly high.
    Ever watch an airplane takeoff? It runs up to takeoff speed, but is still firmly on the ground. Then the pilot deflects the elevator to push the tail down, increasing the angle of attack, and the airplane then is making enough lift to leave the ground. Watch it as it climbs, and you will notice that the nose is directed higher than actual direction of flight...
    Flaps are on the wings, elevators on the tail...
    Flaps can have some or all of these effects:
    Flaps can increase wing area;
    Flaps can shift the coefficient of lift vs angle of attack curve higher;
    Flaps can add drag.
    I hope that this helps.
  7. Feb 28, 2007 #7
    Oct 19, 2003
    5,983
    3,236
    Hey, I just looked up the word decollate (thread title is "how an airplane decollate", and my dictionary has two definitions:
    Remove the head, as in decapitate (which might relate to "taking off")
    Clothing without collars, or open necklines, etc.
    Interesting how that translated...
  8. Mar 17, 2007 #8
    kondordv
    kondordv
    kondordv
    Feb 8, 2007
    0
    Timisoara, Romania
    Re: how an airplane decollate "take off" technique
    Hi all again,
    after long time spending to find and understand the principle of flight and take off for an airplane, I found the answer and it is as I was expected. The Bernoulli principle (Popular explanation) depending of different wing foil, is not enough for an airplane to take off, but Phisical Description (angle atack of wings) is more used and understandable.
    Anyone of you has this two things not very clear in flight technique please visit the page below. The explanation is very very clear.
    http://www.allstar.fiu.edu/aero/airflylvl3.htm
  9. Mar 18, 2007 #9
    CAB
    CAB
    CAB
    Nov 27, 2004
    128
    0
    Colorado
  10. Mar 20, 2007 #10
    RonL
    RonL
    RonL
    Jan 9, 2007
    457
    28
    Texas
    Thanks to both of you for links that will answer, and help with many things that up till now have been less than clear.
    RonL
