Hot wire cutting.
cblink.007
Jul 7, 2014
631
Maryland, USA
I always had trouble using plywood templates. Couldn't get the edge smooth enough where the thin hot wire wouldn't dig in a little and get caught and make a rough place on the surface of the foam. Went with thin aluminum and polished the edges.
The templates for my 25% scale model were CNC cut from 1/8" plywood by Bob Holman Plans from .dxf files I sent him. He did a great job, amd the templates were delivered less than a week after I sent him the files and payment.
Before...
During...
After...
But I have learned that thin plywood templates are good for about 4 hotwire passes before the edges get thrashed by the wire. So, for the sake of absolute accuracy on the full size plug, the templates will be done with SS (vendor TBD), while the wing jigs will be done by Eureka CNC.
Now to go get a boatload of beadboard blocks and a s**tload of Bondo...
stanislavz
Aug 21, 2016
927
Lt
I did uses rollers to solve it in my childhood. make drawing a little harder, but it was worth it. But still gone cnc way as soon as possible.
Geraldc
Nov 12, 2011
521
nz
Just found this foam cutter.
And with this foot it looks like it can take flat strips of stainless that you can form to your required shape for leading edge molds etc.
The length seems to be only restricted by the length of material.
5,867
The ad says it is appropriate for cutting polyurethane foam. Sure, it will cut it, but the person using the hot knife should be breathing outside air under positive pressure at the time to avoid some very dangerous gasses that result.
$120 is a pretty hefty price. A regular soldering gun with a custom-bent wire attached with the normal screw terminals on those guns would be considerably cheaper.
8,912
Very cheap. A scrap piece of #12 copper house wiring works great. Started using it in 1970. I paid $4 for my soldering gun in 1954 and still use it.
wanttobuild
Jun 13, 2015
744
kuttawa, ky
Geraldc
Nov 12, 2011
521
nz
As long as it is bigger than the 100 watt one I tried that would not heat up a long stainless strip.
Jul 29, 2005
14,308
I'm another whose always used regular stainless safety wire for hot-wire cutting. Adjusting the proper temperature is key, as is actually practicing a number of times before you try cutting actual parts. I've always cut with a partner, rather than machine or pantograph. A little practice and a team of two can turn out wonderful cores with almost no wastage.
It's just not that hard.
Geraldc
Nov 12, 2011
521
nz
We don't use #12 copper here but I found a bit of 1/16 copper wire and tried that in my Weller soldering bolt I got for $15 a while ago(the $4 ones were sold out) and fitted it up.
Worked well .Thanks Pops
What I am trying to do is make female molds with compound curves that you can't possibly do with a straight wire and I want to avoid the dust from a router.
sigrana
Oct 19, 2010
64
Australia
I built my two hot wire cutters in the '80s (last century of course) and they are working excellently well after thousands of wings and fuselages cut with them. A simple C shaped wooden or mild square steel tube structure, with one isolated end and an adequate spring (or bungee) on the opposite side, which take care of the obvious wire elongation with temperature changes. I use 0.8mm stailess steel wire, powered by my fully adjustable 0-30V, 0-30A AC/DC power supply, built on a Variac. The varfiable settings are very usefull when cutting different foams and thicknesses.
Protech Racing
Jul 10, 2020
404
Some one asked about the foam guides for cutting ribs. I found a roll of Veneer birchwood that should work fine with a hot wire. Just dont stop..
Lowes .
