I stumbled across this engine recently but can't find any more info or if it's available to any organization too small to have it's own military:
hirthengines.com
It's a 2 stroke, 60 Hp, 79 lb (wet), 2 cylinder engine that runs on kerosene based fuels (Jet A) and doesn't need oil mixed into the fuel. My main objection to 2 stroke engines is the need to mix the oil with the fuel. This seems to solve that problem, it lighter than the 1/2 VW I currently have while being a lot more powerful. Apparently there was an earlier version called the 3503 HF, and I've also seen reference to the Hirth S1204 HF, which is based on the F23, and has 45hp and weighs around 50 lbs.
I was wondering if anyone has seen one, has any experience with one, or knows what they cost. Ideally, the S1204HF would work for my application if it can be found and it's not extremely expensive. 35HF would be overkill power-wise, but still fit.
Other than a potential whopper of a price, is there some downside I'm not seeing here?
35HF Series - Hirth Engines
The home of 2-Stroke engines. Hirth Engines offer outstanding quality combined with unmatched performance and efficiency.
