HERO ULTRALIGHT
philr
Dec 26, 2020
200
Scott from irondesigniowa.com (scottiniowa user name on HBA) has offered to help with the design work for the HERO project. Scott uses Solid Works for CAD and this offers a lot of advantages over Sketchup which I use. We are nearly finished the tube design for the fuselage! Thank you Scott.
challenger_II
Jul 15, 2009
1,095
Fisher County, Tx. USA
Observation: As regards the cabin brace tubes, running from the seat to the rear spar region, it would behoove you to pad those. And, if the pilot is wearing a helmet, he may get his head rattled.
Mig29fuk
Jan 19, 2021
15
Phil Hi from UK.
Having looked at your Hero I recognise a similar configuration to a Ultralight I have here.
I attach photos of my aircraft, a Letov Sluka 2M operationing on a type of Part 103 but called Single Seat De-Regulated (SSDR) here in UK.
Roughly speaking its AUW must not exceed about 300kgs. The 'about' is purely because the Regulations are confusing at best!
Thought you might get confidence from knowing other aircraft out there are using your 'form factor'.
My Sluka has been modified quite a bit as regulation is not a concern. The main changes are creating Dihedral, about 1.5 degrees, upgrading to Rotax 503 DCDI from Rotax 447 and recently adding an e-Prop replacing 3 Blade IvoProp. The Prop change has a significant wieght saving of 3 kgs and is a new profiled 3 blade.
One observation I would make is to consider a little storage space. The Sluka storage availibility is dire. Space is at a premium.
For fun I have added a Cargo Pod, al a Cessna 208......but smaller! I'm allowing it to have an all up weight when loaded of 15kg and that will be situated right under C of G. Can carry overnight bag, few light tools and spares and if required, 10L of Fuel. Might be an idea although with your Fuel Tank being limited range is smaller.
Anyway. Following your idea and best of luck and a short time to flying it.
Regards
Gerry
philr
Dec 26, 2020
200
Phil Hi from UK.
Regards
Gerry
Thank you for sharing pictures and info about your plane. Since part 103 here in the U.S. means the dry weight has to be at or under 254lbs there are lots of things I want to include that weight wont allow. For baggage I was thinking of a kind of detachable backpack behind the seat. There should also be some room for some small things just behind the firewall between there and the fuel tank.
philr
Dec 26, 2020
200
Yes that is a good point. I wonder if bending that tube out will affect its weight carrying ability or compressive resistance to much?
philr
Dec 26, 2020
200
I have decided to change the landing gear design to make something similar to the Aerolite 103 gear legs adopted to 4130 tube fuse construction. 1" fiberglass rod into welded metal fittings at each end.
Lucky Dog
Aug 4, 2021
124
Maybe not. You'll need more triangulation to cantilever those rods. Check out the Rans S18 and Kolb Firefly for inspiration. Also, here's a link to a titanium supplier who has good prices and sells by the inch. Titanium tubes are lighter than fiberglass (for equal strength) and make better springs than 4130 or fiberglass. Tubing - Titanium Joe
philr
Dec 26, 2020
200
Yes I think I will add a flat plate on the outside of the fuselage to further brace the landing gear and upgrade the cross tube to 7/8"x.065
philr
Dec 26, 2020
200
Something like this.
Lucky Dog
Aug 4, 2021
124
That should handle torsion, but I don't think a .875" x .065" tube can handle the bending moment at the mid point. Because the control stick pivots there, a failure might cause problem. Maybe put a 3" x .375" tube
vertical there and triangulate it to the clusters on either side with .5" tubes?
Lucky Dog
Aug 4, 2021
124
This is a Kolb Firefly forward fuselage. It is one of the lighter weight space frames in the UL world, and it's gear sleeves are well reinforced.
philr
Dec 26, 2020
200
I see what you are saying about triangulating but that kolb fuse isn't really what I want and everything I do to take up the torsion loads is adding too much weight. I remembered the gear my Ultravia Pelican GS had and kind of replicated it here but with welded fittings. The design needs two hard points and I think the tube between the legs takes up the torsion loads. The Pelican is composite but I think a tube cluster like this can distribute the loads. What do y'all think.
philr
Dec 26, 2020
200
Here is a pic of the old gear from the Ultravia Pelican GS.
jedi
Aug 8, 2009
3,250
Post 217 copied in error. See next post.
jedi
Aug 8, 2009
3,250
From post # 217 “What do y'all think?”
An ultralight needs to be designed to fail in extreme conditions but the failure needs to be of minor concern and easily repaired.
Birds replace feathers on a regular schedule to fix normal hanger rash.
The landing gear needs to handle normal landings but a few “hard landings” may require an upgrade or replacement part and still be acceptable. IMHO
Don’t overdesign non critical components. Landing gear failures in an UL do not result in fatalities.
That said, the Kolb is a good example and a data point.
