Attaching some photos, rather clumsy to have to e-mail them from my phone and then upload from the desktop, so bear with me....
This is the exhaust valve during the cleaning process. Green Scotchbrite, "Chore Girl" copper sponge, and a brass rotary brush in the Dremel tool. The rope is inserted through the lower spark plug hole, which is quite a bit more of a PITA than the top hole. I finally figured out that surgical sponge clamps (giant hemostats with the loop ends) would force the rope into the hole form below much faster than I could wrestle with it using my fat fingers.
This is the hi-tech equipment I borrowed from Rube Goldberg Scientific Supply Co. (a division of Acme Products). A molded rubber elbow hose connected to a smaller hose that slid tightly over the top of the valve guide. This was filled with the acetone/ATF mixture, and held from spilling by the unused end of the rope. The heat gun was borrowed from a friend, and installed using zip ties to a small piece of copper tube, which was slid into the receptacle of a portable halogen light tripod with the light removed. It gets better... in order to hold the copper tube at the right height (from slipping down into the tripod) a small C-clamp was used on the copper as a stop. I'm anxiously awaiting my Nobel Prize for Science notification letter, likely co-signed by someone named MacGyver, Mr. Goldberg, and his UK licensee Heath Robinson.
Another glamour shot of the gravity-powered Penetrant Oil Dispensing System, along with the Aluminum and Bronze Thermal Heating & Expansion system.
Two mug shots of the perpetrator of this heinous crime. The hero of the day was the McFarlane special cleaning reamer, with Lubri-Plate grease, which apprehended and imprisoned the perpetrator... some nasty black gunk that took a little effort to get out of the guide.
This is the aluminum bushing that my friend made, slips over the outside of the valve guide and keeps "Rocco the Ramrod " from going where I don't want him. (Rocco is my mob enforcer, a turned down long rivet set that is about .020 smaller than the valve stem).
More photos when I find them.
