Photos to clarify description of my approach to the "Lycoming Rope Trick" (actual SB is in my files, forgive the popular term it has come to be known by).
above - using a piece of bare brazing wire (bronze) through top plug hole, to help lasso the valve
secure. run the knurled nut down on the handle to snug the cable loop.
Valve removed. Push it down with a wooden dowel, or a piece of aluminum round, if tapping is necessary.
Guide it with the loop, and avoid banging on the cylinder wall.
Tool shown above is a bronze scraper for the valve stem deposits that build just below the guide area & can split the guide if they grow. Inner face of the tool is milled to same diameter as valve stem. (For convenience, better/deeper fit near sparkplug hole, "sharper" end). Other than that, there is nothing special about the shape - it was a convenient, suggestive shaped piece from other cut-outs in a piece of cast 954 scrap. Mic the barrel or use verniers down at the stem to verify diameter as each end and middle of the sliding surface.
Above shows the machine tool straight shank collet chuck described previously, on the left. To twist and tap valve on seat to break up light deposits and improve seal. This is for a valve that seats easily and clearly, but does not seal because of "crud". As TFF stated, if the valve does not seat easily because it is hanging up on one side, it is bent and should be replaced. Before the head comes off.
I had forgotten the shop made split collet on the right as a loaner, made from a reject from a batch of mortise machine reducer collets. (just a straight, reamed to size bore. In this case quickly bandsaw-split, de-burred, and closed with a cross bolt.) The knurl is a convenient artifact of the original reject blank for the original purpose. Exhaust valve barrel is larger than the intake, but the reduced section of the stem is the same size. So the same size collet, any style, will fit either.
