Heat treating steel landing gear
Discussion in 'Tube and Fabric' started by Dana, Jun 30, 2010.
  1. Jun 30, 2010 #1
    Super Moderator Staff Member
    Apr 4, 2007
    8,633
    3,015
    Guess this should go in that "miscellaneous" section that doesn't exist yet, but..I do.
    I'm looking for input on an appropriate strength to heat treat a 4130 landing gear. Actually it's the tailwheel strut of my Kolb, which has bent a couple if times. I pulled it, heated it up, and bent it back straight again, but likely it'll just bend again (it's 5/8 diameter tubing). It is intended to flex for some spring action. Obviously I don't want to harden it to the point it gets brittle, but something higher than annealed or normalized might make it hold up better. But I have no idea what's a typical value for spring steel gear legs.
    -Dana
    Starve a feeding bureaucrat...vote Libertarian.
  2. Jun 30, 2010 #2
    12,064
    2,355
    Well annealed is about 65ksi. Normalized is about 80ksi. I would guess 125ksi-150ksi.
    How to do this?
    I think it is first heated cherry red for some time then quenched in used motor oil. Then it needs to be tempered. (heated to some lower heat for a time). I have heard that this temperature is what you get with a blueish/ purple color that appears on a polished clean area.
    BB
