Head wing cantilever.
stanislavz
Aug 21, 2016
1,078
Lt
Spin off from shoulder wing / cantilever high wing two seater.
This one airplane : CZAW Parrot - Wikipedia Puts pilots head in front of main spar. Price for this - forward swept wing.
Do other know similar designs ? I really do not see any other possible option to have perfect visibility without feeling of driving from rear seat of a car.
Bill-Higdon
Feb 6, 2011
1,611
Salem, Oregon, USA
Viking SF-2A Cygnet or if you can find a kit then the Andreasson BA-7, Bolkow Bo.208, Malmo Flygindustri MFI-9
rv7charlie
Nov 17, 2014
2,185
Pocahontas MS
Or, just design the fuselage with an extra 6-8 inches of height. If you're paranoid about fuselage cross sectional area, think of it as a Questair Venture fuselage turned on its edge (not a lot of speed penalty in a Venture for the extremely wide cockpit), or think of it as having a belly pod (common on singles in commercial operations) over your head instead of under your seat.
Riggerrob
Sep 9, 2014
2,255
Canada
Stemme motor-glider achieves the same configuration by re-balancing the engine. It is located in the center fuselage - under the wings' center section - and a shaft extends forward through the cockpit to the prop hub.
That would also be possible with an electric motor mounted in the extreme nose but batteries or ICE generator aft of the cockpit.
When forward sweep is less than 10 degrees, it behaves structurally and aerodynamically like a straight wing.
stanislavz
Aug 21, 2016
1,078
Lt
No, i am not paranoid, i just do not see it elegant.. plus felling of driving from back of the seat in a car.
rv7charlie
Nov 17, 2014
2,185
Pocahontas MS
I don't see your point. Raising the wing allows the same seating position as a strut braced high wing. Do you feel like you're driving from the back seat in a C172/182?
Turd Ferguson
Mar 13, 2008
5,829
Upper midwest in a house
Cessna put the pilot's head well in front of the wing spar on the Model 177. They didn't need to sweep the wing forward but did move the spar back to ~40% chord which helped. They were not able to get adequate pitch authority with a stabilizer/elevator so they switched to a stabilator.
stanislavz
Aug 21, 2016
1,078
Lt
But it is a 4 seater.
stanislavz
Aug 21, 2016
1,078
Lt
kind of..
Ok, thank you all for replays, it is not an easy goal for two, side by airplane.
stanislavz
Aug 21, 2016
1,078
Lt
But it works with 2 people in the front seats - like a 2 place.
Just take out the back seat if ti's a problem and have a camping airplane.
By having tail as an extra ballast ? Ok, my current bird is an skyranger in egg phase. Heads back rest at wing rear spar. Similar is in kitfox and other small, ul class birds. + you have fuel tanks behind seats. And all this to counter weight of an engine..
How can you do it by placing 50% of mtow in front of spar ?
Niels
Aug 15, 2019
145
Plus the good looking ARV2
Nice plane
An 60kW/2400 rpm electric motor up front and a 30 kW genset in each strut -wing junction.The wings can even have sweep back then.
stanislavz
Aug 21, 2016
1,078
Lt
Nice plane
Plus i think i have read a story on how hard it was to put different engine after two strokers ran out of production. Due to higher weight.
