That’s why I try to make sure I add a laughy face emoticonSome here post “tongue in cheek”. The fun part is that not everyone gets it.
This. There was a time when I found this forum to be logic and engineering based - among the best aviation forum on the web. I used to actively steer my co workers (almost exclusively engineers and flight test professionals) to this site, but now I only mention it in passing, usually with the disclaimer that there are some "fanciful" ideas out there. I'm now almost embarassed at some of the juvenile content found here....Even if it's not politics, allowing threads about amphibious airliners made out of bamboo and organic hemp fabric powered by forty people pedaling with oxygen supplied by onboard algae tanks just dumbs down the whole forum so a serious new homebuilder who wants to talk about airfoils or wing rib construction just says, "what a bunch of whackos," and goes elsewhere.
I'd say this: An obscure or flaky or not-at-all-related-to-HBA thread is a LOT less irksome if it has an accurate descriptive title. I can pretty much tell right away if I want to open and spend time on a thread about a neutron rocket. But threads titled like:"Have you seen this?" are IMO, inconsiderate/ rude.
but isn’t the problem but on the average homebuilding is about the wackos?Other aviation forums have at times tried adding a subforum for off topic stuff where political discussion is allowed. They've found, multiple times, that the bickering there gets out of control and the bad feelings spill over into the on topic areas.
All aircraft are design compromises in performance and safety. Certified factory builds lean on the side of safety while homebuilts tend to but not always lean toward performance. John or Jane Q public might be surprised to learn how much " homebuilders" contribute to the design of what eventually become certified factory builds.but isn’t the problem but on the average homebuilding is about the wackos?
People tend to home build either at a cheapness or because they want a different set of compromises that have been made before.
almost by definition if you want to do something that hasn’t been done before you’re welcome.
Recently there was a thread illustrated how widely separated we can be on those points . A poster pointing out that the seawind it’s not designed to be the safest aircraft. It seemed difficult for him to accept that many here consider that to be a good aircraft because it does what it was optimized for even at the cost of some safety.
I suspect that the general population would think that we’re all wackos for choosing to build aircraft that are not as safe as they possibly could be.
I haven't built a plane either, unless you count a paramotor. But I've owned 5 homebuilts if you include ultralights, and either restored, fixed, and/or improved all of them. I don't know that I'll ever actually build an airplane; I'd like to but I have far too many other projects and priorities. Maybe when I retire...I’d like to make a confession here I’ve said it before but I’d like to be absolutely clear that I do not think I will ever build an airplane....
Currently my best case scenario is purchasing either a completed home built or a very nearly completed home built.
Not sure how to "fix" it.... But HBA would be better if...
One of the first posts I put on a forum got this reply,"what planet are you on?" Now this is translated here to be a bit derogatory.Some here post “tongue in cheek”. The fun part is that not everyone gets it.
I miss Choppergirl and a few others also. RIP all exHBAers. I was nearly one of you once and thought I was unfairly judged but likely I was simply misunderstood.Bring back Raptor!And where has choppergirl gone?
If your missing chopper girl go to the Media section on the site and you'll find many pictures posted by that girl. That was one area that made this a better site.I miss Choppergirl and a few others also. RIP all exHBAers. I was nearly one of you once and thought I was unfairly judged but likely I was simply misunderstood.
I hope to someday try again to get the idea across.
Either I never knew we had a media section or I forgot about it. Probably the latter.If your missing chopper girl go to the Media section on the site and you'll find many pictures posted by that girl. That was one area that made this a better site.Media section that is
Good question . Fits right in with aircraft building and Kits wouldn't you say.Either I never knew we had a media section or I forgot about it. Probably the latter.
So what's with her dead (or near dead) cat picture from 4/29/19? There aren't any comments to explain it.
If you want to go faster than the speed of light slow the speed of light.............
"The person who figures out how to travel faster than the speed of light most likely will NOT be the one who says "It can't be done."
So now I have to rethink E=MC2. How can a constant C be a variable ?Light travels at approximately 300,000 kilometers per second in a vacuum, which has a refractive index of 1.0, but it slows down to 225,000 kilometers per second in water (refractive index of 1.3) and 200,000 kilometers per second in glass (refractive index of 1.5).
