Hawker Hurricane replica
Discussion in 'Warbirds / Warbird Replicas' started by PTAirco, Jan 7, 2008.
  1. Jan 7, 2008 #1
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
  2. Jan 15, 2008 #2
    And me! Bloody nice, though!
  3. Jun 22, 2008 #3
    pylon500
    pylon500
    pylon500
    Dec 26, 2003
    270
    Taree Airport Australia
    As we would say here in Australia, "Bugger, I was going to do that!"
    Now I'll have to find something else to design, to be different.
    How about a half scale Rotec powered Bearcat?
    Arthur.
  4. Jun 23, 2008 #4
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,550
    320
    Sydney
    Yep,
    You think of it and some other buggers done it before.
    Bearcat sounds good, what about FW190 with Rotec?
    Litespeed
  5. Jun 27, 2008 #5
    macosxuser
    macosxuser
    macosxuser
    Jan 21, 2007
    52
    0
    I like it, except the rotex...
  6. Jul 10, 2008 #6
    bencmaster
    bencmaster
    bencmaster
    Jun 5, 2008
    10
    0
    UK
    I shall watch that one with interest
    very sweet apart from the noise.
  7. Jan 20, 2009 #7
    wiloows5050
    wiloows5050
    wiloows5050
    Jul 28, 2007
    249
    220
    Elk Grove Ca
  8. Nov 11, 2009 #8
    pie_row
    pie_row
    pie_row
    Nov 9, 2009
    710
    salt lake city Ut
    I want to build a 50% Hawker Hurricane with a home built V12. Use the old Gram Lee -11 building method.
  9. Nov 19, 2009 #9
    wiloows5050
    wiloows5050
    wiloows5050
    Jul 28, 2007
    249
    220
    Elk Grove Ca
    I'm currently working on one of Gram Lee N11. Robert is working on a Camel with steel fuselage and with reat of the process the same. I'd be worried about the stress on the wings. They would have to be beefed you considerably.
  10. Nov 20, 2009 #10
    pie_row
    pie_row
    pie_row
    Nov 9, 2009
    710
    salt lake city Ut
    The wing will take some work to design. I've been looking at what Hawker did with their design to take the loads. They wrapped the spar tubes with sheet to get enough strength, something like that will be called for.
  11. Nov 21, 2009 #11
    wiloows5050
    wiloows5050
    wiloows5050
    Jul 28, 2007
    249
    220
    Elk Grove Ca
    If you go to hurricanerestorations web site there are pictures of the center section which was quite complicated.
  12. Nov 21, 2009 #12
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    ? Hurricanes used built up spars, made from rolled, corrugated sections of high strength steel, all riveted, bolted together with many complex joints and with gussets. The spar boom sections varied and some had internal liners. The early versions used a Warren girder bracing between the spars with fabric covering for most of the wing, the later ones had all metal covering.
    All very sturdy and from people I have talked to who flew them, the whole airplane was pretty much indestructible in flight. Pilots were much more careful with Spitfire wings.
