HAD Foil - Airfoil generation program for Windows-
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by TinBender, Feb 16, 2015.
  1. Feb 16, 2015 #1
    TinBender
    TinBender
    TinBender
    Mar 4, 2010
    218
    53
    Charlotte, NC, USA
    HAD Foil
    Greetings,
    Because I found limitations in MS Excel noted in https://www.homebuiltairplanes.com/...ga-airfoil-coordinate-generation-windows.html , I have created a program that is not limited. This new program is written in Visual Basic.NET with an SQL server built-in for unlimited database capabilities.
    -Features tables that may be edited to increase the number of available forms and mean lines.
    -Editors are found under the Edit Tab.
    -You will probably be required to install a file or two from the internet during install to handle the SQL database.
    -To remove the program you will need to use the "Programs and Features" link in the Windows Control Panel.
    Exporting functions will happen sometime in the future. I also need to do work on the NACA mean lines. They are included only because I wanted to get the data into the table at the time. They will need an additional selectable parameter to work.
    View attachment HAD Foil.zip
    Norman likes this.
