H bracing in aluminium spar tubes
Blackhawk
Apr 18, 2008
240
AUSTRALIA
Anyone have knowledge of fitting H braces to load bearing areas of aluminium spar tubes.
Just wondering whats best to use; 4130 or 316 stainless steel.
14,702
Not quite sure what you are trying to do, but aluminum would be the best material.
challenger_II
Jul 15, 2009
200
Fisher County, Tx. USA
TFF, he is referring to the method Homer Kolb used in his aircraft.
OP: chrome-moly structure, and coat it with zinc-chromate. The stainless H-frame would be heavier, and would be a beast to drill the holes for the rivets. Hope this helps.
Blackhawk
Apr 18, 2008
240
AUSTRALIA
Thanks,
Stainless steel is less than 1.5% heavier than the same size 4130 tubes.
The holes shouldn't be that difficult with the lubricants available today.
It is also cheaper than 4130 here (4130 has to be imported)
8,958
Check to see if the stainless you want to use will cause any "galvanic" corrosion in aluminum. The stainless may not corrode itself, but it might create an environment where the aluminum touching it would corrode. I know Titanium will do that on some materials.
