That wasn't good! :cry:Lol, no need to post optical illusion ones, when it happens for real. Here is the prop fall off video that made me groan and say "Great, yet another thing I have to worry about..."
I get it. You're right. Thanks. I was wondering W T H-ll !?Nope, its not real, in fact he admits so in his post. All you have to do is watch this video I included a link to in my original post to see the illusionbL in real time:
[video=youtube;D3xpEQnizMg]https://www.youtube.com/watch?v=D3xpEQnizMg[/video]
The more dangerous illusions, are the ones where your bodies senses are telling you one thing is happening, when the complete opposite is happening... like with balance and movement and your inner ear. We become acustum to believing our senses 100% of the time, because typically they are... until they aren't:
https://en.m.wikipedia.org/wiki/Sensory_illusions_in_aviation
Wow, I counted 33 blades it shed during the video! Amazing that they survived.All you have to do is watch this video I included a link to in my original post to see the illusion in real time:
I find the whole story posted a little odd. If Aerovees are as horrible as this guy alleges, how come they're not falling out of the sky all over?While it didn't happen in flight ... here's what a prop looks like when it falls off:
[video]https://youtu.be/2F413qW8X3Q?t=275[/video]
If you watch the video the pilot was about to take off but something seemed wrong. Great idea to pay attenwhen the hair is standing up on the back of your neck ...
If by "front bearing" you mean "rear bearing," as in pulley end, yes; just as the vast majority of VW conversions have.So the Sonex engine just has the small VW front bearing?
Please review the props recommended by Sonex/Aeroconversions, and bear in mind that the "composite" prop is a wood prop with a composite covering. Whatever the cause of this crankshaft failure was, it is extremely unlikely that the prop was it. I rather suspect the builder (since there are many Aerovee builders who have not had a similar experience).Looks like he had a composite Sensenich prop. Usually they recommend wood for VW.
Certainly not my intent to turn this into an "Aerovee crankshaft debate" but to give you my take on it. There were a few failures of the original early crankshaft/shrink fit prop hubs used on the Aerovee. Most were blamed on incorrect assembly by the builder and at least one on low oil pressure. Jeremy pointed out that, according to their records, no factory assembled original crank/hub assembly had ever failed and none of the new design units had ever failed whether factory or customer assembled. My first Sonex had the original crank/hub set up and I flew it 175 hours before selling it and building my Corvair powered tail dragger.I find the whole story posted a little odd. If Aerovees are as horrible as this guy alleges, how come they're not falling out of the sky all over?
The black Sensenich props that I have seen are hollow carbon fiber, no wood core.Please review the props recommended by Sonex/Aeroconversions, and bear in mind that the "composite" prop is a wood prop with a composite covering. Whatever the cause of this crankshaft failure was, it is extremely unlikely that the prop was it. I rather suspect the builder (since there are many Aerovee builders who have not had a similar experience).
From Sonex -- The Sport Aircraft Reality Check!:The black Sensenich props that I have seen are hollow carbon fiber, no wood core.
Sonex also recommends using fixed-pitch wood or wood core with composite coating. These props are a light-weight, reliable, and affordable option for your Sonex Aircraft.
Wood props are offered with a Natural Wood Finish with Red Safety Stripes at prop tips, and Matte Black finish on back of propeller.
Composite Coated, or "glass" props are available in:
Black with Matte Black finish on back of propeller.
Gray with Matte Black finish on back of propeller.
White with Red Safety Stripes at prop tips and Matte Black finish on back of propeller.
