Thanks for the kind words everyone
I have recreated the wing in Compufoil and will be cutting the ribs on a cnc router. I figure that will get me a cleaner/truer airfoil than the traced blueprints. Cowl will be similar to a James style used on RVs. Will use individual plenums on the cylinders to keep the air where it needs to be. I have a set of Vans leg spats and wheelpants to clean the gear up. Tailwheel fairing will be home brew but clean and will flow into the tail stinger.
Here's a couple pics of my Kitfox I completed in July. IO-340 (I built it), 80" WW STOL prop, AV Weld mains, T3 tail shock, SDS IGN/FI system. 1013 lbs and 2600'/min and more climb! Custom FWF including cowl.
