GM LH7 1.6 diesel engine weight thread.
KeithO
Nov 29, 2009
788
Jackson, MI
How do you think the HP pump works ? Best case scenario it is a vane type but a lot are piston type pumps so have erratic loads on the drive system regardless....
dog
Dec 29, 2019
741
I did not and have no plans of it at this point. I believe a mechanical plunger type pump would be the death of this chain drive setup with it's erratic resistance on the drive side.
the cam will be a(erratic) variable load,larger than an injection pump,and the oil pump will also have a cyclic load,and the whole drive will acelerate and decelerate with each piston firing event
,even a common rail pump will see pressure changes with each solinoid firing,
is there a good way to incorporate a ve pump ?and or,is there an ECU for the common rail that will never go into limp mode?
for dealership moniti$ation reasons
Chris Matheny
Nov 26, 2019
264
St. Paris OH
If anyone is interested, I'll probably sell this engine as it's doesn't fit in my plans. 33,000miles I'll just want back my investment and can deliver for a small mileage fee. PM me if interested.
Jazz30-06
Dec 29, 2019
22
Motec, Bosch motorsports and Baldurs DID1 will all run a common rail system and are stand alone so no limp mode will activate unless you program it to.
For what it's worth, I wouldn't touch another Bosch unit with a 100ft pole. The variables make no sense because they are all German-based, there is no such thing as a real manual, and there is only one person in the states that sells/supports them... and he's a pretty busy guy.
thompsonbb
May 5, 2021
9
I'd be very curious how much a 3.0L Duramax LM2 engine would weigh, stripped of all the emissions controls and unnecessary bits. Specs show ~475lbs dry.
Tom DM
Mar 31, 2022
289
EBGB Grimbergen airfield (N of Brussels, Belgium)
Yeah, the metric system is indeed a PITA... luckily the English have (re)seen the light and are now obliged by Law to use their Imperial, ex-Britannia Rules the Waves, measurements. Stones, pints, imperial gallons... Just as you think the rock in the North Sea couldn't drift further from Ostend, they do it.
Ignoring Bosch sounds about as easy as ignoring China: with the latter your clothes will probably fall off, with the first useless to run nude to your car as it will likely be as dead as a dodo.
Chris Matheny
Nov 26, 2019
264
St. Paris OH
I'd like to know also but I'm not willing to pull the engine out of my new truck to find out. On our recent trip to Florida and back to Ohio we averaged 29.3mpg down and 30.9mpg back. Truly amazing in a half ton pickup.
