GM LE2 engine conversion
Discussion in 'Chevy' started by Chris Matheny, Dec 11, 2019.
  1. Jan 7, 2020 #41
    Jazz30-06
    Jazz30-06
    Jazz30-06
    Dec 30, 2019
    6
    1
    A recommendation, if I may. I would run all injectors all of the time if you can control fuel well enough. That way you can switch to whichever is still a "good" bank if need be and know they were firing previously.
    Chris Matheny likes this.
  2. Jan 7, 2020 #42
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    I had thought about that but with the complete two Lane harness and ECM setup I'm planning it will not work. I'll likely just fire the engine on the one system to make sure everything is good then switch to the other system for flight just like checking mags/plugs before takeoff. All plugs will be firing all the time but will have a check to momentarily kill one set then the other to check plugs and coil packs.
  3. Jan 8, 2020 #43
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    Well, while milling the top off my valve cover tonight I moved the setup back to final cut the areas under my clamps and ran the valve cover right into my Z axis way covers and broke the valve cover casting. Good thing I have another one I will cut tomorrow. This will then be used to make a plug and mold for the carbon fiber valve cover. Ahh one step forward and two back. I did get all my locations finalized for the sheet metal intake manifold flange.
  4. Jan 8, 2020 #44
    cheapracer
    cheapracer
    cheapracer
    Sep 8, 2013
    5,807
    4,266
    Australian
    Covers these days are often an integral part of the head's strength. You might want to check that with GM.
    Then there's the heat transfer factor, valve covers are also often an integral part of that scheme as well.
  5. Jan 8, 2020 #45
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    Luckily that's not the case here. It's a big part of the PCV system that I will not be using their setup.
  6. Jan 9, 2020 #46
    Jazz30-06
    Jazz30-06
    Jazz30-06
    Dec 30, 2019
    6
    1
    Wait, you're running two completely seperate EM systems?
  7. Jan 9, 2020 #47
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    Yes, two ECM's on all separate sensors and injectors.
    stanislavz likes this.
  8. Jan 9, 2020 #48
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    How do they know, to add twice the fuel, when one is dead ?
    + alive one, have to shut down power from dead ecm - mosfet 99% fails as short circuit, so, they will flood engine.
    And for full power you do need not 4 injector at all. Multipoint injection is necessary for low power only.
    So - i would go for two tbi injector, one per ECM, and some sort of "watchdog"
  9. Jan 9, 2020 #49
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    Only one ECM and set of injectors will be active at a time. If in flight any one point of failure occours you will be able to switch to an entirely new system for safety.
  10. Jan 9, 2020 #50
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    I was installing aftermarket ecu in high schools for some years - i would not like this solution. The biggest show stopper was sensors/vonnectors. Sometimes - lost sync due to emi. And you cant just on the fly swith on/off ecud -You still need an time to sync timing whell. Plus sparks dont like to be left cold. I suggest to ru ecu all time, just turn on/off only injector banks. Coils hot all time.
  11. Jan 9, 2020 #51
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    And i do think from time to time on magneto like electomechanical fuel injector - mechanical low pressure fuel pump, normal injector pulsed from magneto like coil. Sorry off-topic
  12. Jan 10, 2020 #52
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    All coils will be hot and all plugs sparking every time. The switchover from one ecu to the other would not be on the fly. If engine died in flight it would be a simple switchover and restart situation.
  13. Jan 10, 2020 #53
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,566
    3,402
    Mojave, Ca
    At 300 feet over trees on the departure end of the runway a simple switchover/restart might burn more time than available
    pictsidhe and stanislavz like this.
  14. Jan 10, 2020 #54
    stanislavz
    stanislavz
    stanislavz
    Aug 22, 2016
    392
    100
    Lt
    Shall i draw a circuit for it ?
  15. Jan 11, 2020 #55
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    This would hold true in a certified engine also.
  16. Jan 11, 2020 #56
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    Location for the secondary crank sensor machined. Clears flexplate.
    akwrencher likes this.
  17. Jan 23, 2020 #57
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    Got all my big parts of my redrive done. Now I'll have to get the shafts splined. There is some room to shed weight on it after proof. The second prototype might be a casting, time will tell.
    Jazz30-06 likes this.
  18. Jan 25, 2020 #58
    Jazz30-06
    Jazz30-06
    Jazz30-06
    Dec 30, 2019
    6
    1
    Why change to a casting? You already have the billet piece which should be more uniform in structure and therefore stronger/lighter.
  19. Jan 25, 2020 #59
    Chris Matheny
    Chris Matheny
    Chris Matheny
    Nov 27, 2019
    54
    34
    St. Paris OH
    I will only change to a casting if this box proves itself and there is a market. All bearing, shaft and gear loads are designed around a 600lb-ft at 2700 with a 2000hr TBO and 99.9% bearing reliability. I should be testing it in the spring on a stationary test engine. Time will tell. There have been smarter designers than I fail but it will be an learning curve on the 3 designs of torsional vibration mitigation I have in my pea brain.
    Jazz30-06 and Vigilant1 like this.
