ivanhoyt
- Joined
- Sep 19, 2021
- Messages
- 13
I want to be able to use a production automotive engine with 100+ hp at 2700 rpm. I'm a proponent of keeping things as stock as possible. In my research I run across the LH7 GM turbo diesel and after looking at the hp/torque/rpm (dyno) chart, I wondered if this could be used to driving a prop directly off of the flange end of the crank through a BMW drive shaft vibration damper. The prop hub would require its own bearing, of course. One concern is the low placement of the crankshaft which would create a ground clearance problem for the prop. If there was a way to run this engine upside down it would resolve that but my goal is to keep it stock. Definitely not a stock situation (-;
