Armilite
Generac 992cc V-twin four cycle with EFI. Probably to Heavy for most Part 103 at 120lbs. A Smaller CC/HP V-Twin was 94lbs. You might be able to strip off some weight.
https://www.brandnewengines.com/61E477-0007.aspx
37hp Briggs VanguardNew EFI: Enables up to 25% fuel savings
1-1/8" x 4" shaft, tapped 7/16" with 1/4" keyway.
Cast iron sleeves, full pressure lube w/ oil filter,
electric start with 20/50amp alternator, advanced debris management system,
Less fuel tank, less muffler.
Universal replacement engine for pressure washers, saws,
compressors, rollers, log splitters, etc.
3 year warranty.
Model 61E477-0007.
160 lbs
Vanguard™ 37.0 Gross HP* EFI
Vanguard™ is the innovator and proven leader for BIG BLOCK™ V-Twin engine power, performance and reliability. For the most challenging applications—where downtime is not an option—this BIG BLOCK V-Twin engine lineup has been expertly engineered to deliver the dependability hardworking people need to get a lot more done throughout the day.
Typical applications include: Concrete Trowels, Chippers/Shredders, Commercial Mowers and Mud Boats.
Compared to a Hith F-23(50hp) 78lbs, including reduction unit, full exhaust, and electric start or71lbs with recoil start reduction unit and full exhaust.
3 year warranty.
Model 61E477-0007.
160 lbs
