Gearbox Chip Detector
Toobuilder
Jan 19, 2010
5,018
Mojave, Ca
The HIO Lycoming I have out in the shop has a chip detector in the oil sump. Might look at Lycoming parts manuals for a PN.
Pale Bear
Feb 22, 2009
42
Minnesota
All of the Military Helicopters I worked on had them also, yes some false alarms but prevented a lot of crashes, lost equipment & lives.
Ah yes, .. chip detectors. I believe that Hueys had 4 of them. In peace-time, they having the luxury of jerking out the possibly bad component and sending it away to depot level maintenance, to get scrutinized. I don't recall if they (depot) would report back to the flying unit, about what they found, on that suspicious part, or not? I should add, .. a drain & flush of the oil, most likely happened then too, and an oil sample would be done, right away .. so maybe removing & replacing wasn't always done? I was a part timer, .. not really in the loop, about these kinds of things.
My Guard unit went to depot, (Corpus Christi) a few times, for our annual training. I got a chance to work in non-destructive testing, at one point .. handle parts & examine them .. look at them with black lights, .. for cracks. Worked there for a day, .. I didn't find any dingers.
pfarber
Feb 21, 2019
670
Pennsylvania
Don,
Sounds like they must be pretty simple gadgets. If we are expected to build one, we would need to know how it works, what critical dimensions or detail characteristics it is to have, etc. Please tell the us (or the OP) the important details or point us to documents that have them.
Bill
A magnet, led and a photosensor are all the basic parts. Im sure you can get 12v parts and not even need a regulator.
Cutting a hold in your case, well that's the real question.
Mike0101
Aug 24, 2020
28
If you are still looking:
https://meggittsensing.com/wp-content/uploads/2017/02/7-Datasheet-oil-debris-monitoring-Detector-...pdf - Meggitt (I've used some of their products, mostly accelerometers).
Magnetic Oil Debris Sensing » Gill Sensors & Controls - - Gill (various industries up to F1). Can likely source in USA through company such as Burns Stainless Steel.
Condition Monitoring Sensors, Metal Particle Sensors, Water-in-Oil Sensors - Eaton - Filtration - Eaton.
Doubt any of above will be a simple drain plug replacement.
TXFlyGuy
Apr 25, 2012
1,985
Republic of Texas
At this stage, a chip detector would be useless. My oil is full of metal, as the gears are now breaking in. Oil change schedule is every two hours.
