Garmin EFIS Failure Rates?
TXFlyGuy
Apr 25, 2012
1,783
Republic of Texas
Does anyone know the actual failure rate history of the Garmin EFIS display? How about the ADAHRS failure rates? Or, do they never fail?
Can you run a single G3X Touch, and have dual ADAHRS?
13,081
You can have two ADAHRS with either calibration. Failure probably few if none yet, but it is man made, it can fail. The only problem with Garmin equipment is the rape Garmin does if it does fail out of warrantee. Garmin has too much at stake to put something out bad.
TXFlyGuy
Apr 25, 2012
1,783
Republic of Texas
I simply called Garmin. Zero failure of EFIS screens that they knew off. The technician said he has never replaced a single screen.
TXFlyGuy
Apr 25, 2012
1,783
Republic of Texas
Read the October issue of Kitplanes magazine and get back to us if you still want to fly IMC with a single screen.
Never stated that I (or anyone) wants to fly IFR with a single display. Only wanted to find out the failure rate for the EFIS display and the ADAHRS.
Decided to go with the G3X Touch, plus the GRT Mini as a backup. Both with ADAHRS, both with independent battery backup. The odds of me having a heart attack inflight are greater than the odds of losing both of these displays simultaneously. Oh...that's not good!
SVSUSteve
Aug 20, 2007
3,894
Evansville, Indiana
Both of which are roughly the same odds as this Jew being elected the next Pope. LOL
SVSUSteve
Aug 20, 2007
3,894
Evansville, Indiana
The first Pope was a Jew, as was his mentor.
Touche. But given that there hasn't been a declarative Jew as Pope in around 2000 thousand years, the analogy still stands. The odds aren't great.
Neither one was a pilot, although that was not an impediment to one.
Kind of like the joke that was translated to me by a Polish friend about how John Paul II was a "fine Polish boy who was for many years the Pope and is now the country's main airport". Somehow, I think it loses some of its humor in the translation. LOL
  • Like
Reactions: BJC
5,352
We have several customers flying the G1000. We've seen a couple of AHRS failures and yesterday we replaced a magnetometer, which is also known to fail occasionally. The magnetometer is the thing we used to call a flux gate (it senses the earth's magnetic field for the HSI's heading function) but in these systems that magnetometer also senses the inclination of the magnetic field (magnetic dip) and uses that info as part of the attitude reference. The magnetometer communicates with the AHRS. We couldn't get attitude reference with the magnetometer dead.
Of all the systems in an airplane or a car or truck or motorbike, the electrical system is the most vulnerable and prone to failure. In engines it carries as much as 90% of the legitimate blame for performance problems. Ironically, electrical and electronic systems are the weakest area of knowledge for most mechanics as well as aircraft owners, which is why we are forever reading unhelpful suggestions that the fuel system or carburetor are at fault when someone is describing some engine problem. Traditional airplane engines have one fuel system and one carburetor but they have two magnetos, which tells you something about the habits of electrical devices. Some airplanes have two alternators on one engine. The G1000 airplanes have two batteries and SIX buses (older non-G1000 airplanes had two buses).
I love working on electrical and electronic systems. I started fooling with electronics 50 years ago. But that experience also tells me how many ways they can fail and how difficult it can be to find the gremlin, and how carefully these things have to be designed and set up. In airplanes vibration is a big problem with these systems, too.
SVSUSteve
Aug 20, 2007
3,894
Evansville, Indiana
I don't feel so bad then. The rough layout of the electrical stuff for the Praetorian has five primary plus an emergency bus.
Guess who will be getting a LOT of PMs when I get to the electrical detail design phase. LOL
8,179
Dan Thomas-- When my youngest son was about 19 years old in the mid 80's, he built his own flux gate that also sensed the inclination of the magnetic field and fed to a computer that he designed and built, ( I designed and built the PC boards for him) and made a nav system much like a gps. Just had to tell it what hemisphere it was in.
I also have been interested in smoke in wires since I scratch built my first model airplane RC radio equipment in 1958.
Another Dan
SVSUSteve
Aug 20, 2007
3,894
Evansville, Indiana
That's pretty impressive, for both of you. *tip of the hat*
8,179
The down side was the local mag field disturbances from iron deposit's.
My son got interested in the stock market when he was 12 years old and the nav project got put on hold and forgot about when at 24 years old, a semi-truck tanker hit him head on while driving on the interstate at night and spend 2 years in hospitals with a head injury, after that his full effort went to the stock market. Did very, very good. Now 50 years old with 2 boys.
Dan
SVSUSteve
Aug 20, 2007
3,894
Evansville, Indiana
Dan
At the risk of sounding like a suck-up, he did well because he was raised well.
Not to insult you by comparison to an elder, but your attitude reminds me a lot of my grandfather's. He raised me to give respect where it is due and if I was curious to learn about it to the greatest degree possible. I owe him a lot and still think of him constantly even though he's been dead over a decade now. There's still a lot for me to learn and try but he helped a lot in setting the stage for me to do so.
You and I don't see eye to eye, but I still learn a lot from your posts both directly and by them leading me to think more about my own ideas. Thank you for that.
8,179
Steve, I also learn a lot from your post, glad you are back. I grew up with my grandfather (1876-1959) and also miss him. Great man.
Dan
TXFlyGuy
Apr 25, 2012
1,783
Republic of Texas
Question: Should we go with dual Garmin G3X Touch EFIS displays (dual ADAHRS), or a single G3X Touch and a GRT Mini-X?
Why?
