Dan Thomas;414106]They used rubber not because that's all they had at the time; they used short pieces of it as couplings in areas where they either needed some flex, or they had too little access for aluminum AN fittings. The rubber was MIL-6000 hose (not "rubber") and it's still available today,
The problem with quoting just Mil-6000 hose is that there are different types of hoses specified. A builder needs to research just which hose might meet his needs with the proper spec.
Some are compatible with fuel and some are not. From what I'm aware of,
the fuel hose available in older airplanes was always rubber. As I mentioned, there are newer alternatives that are better even if they do/do not happen to meet a Mil-Spec. I would think that all the major manufacturers of hoses do meet and probably exceed some Mil-Spec, and definitely handle different types of fuel. In todays world, a homebuilder should certainly build his airplane with the realization that even if he doesn't plan to use auto fuel, it might be wise to build with that future possibility in mind. Not to distant memories recall the problems that were created in the automotive industry and even in aviation when the petroleum industry started modifying fuels. Rubber was one of the major problems with different fuels. Nowadays its common to use compounds which are impervious to current fuels.
but some manufacturers are also issuing modern fuel injection hose as a replacement for it. The modern stuff will tolerate ethanol, while some of the older compounds won't. Furthermore, teflon hoses are regularly used in the engine compartment because of their tolerance to heat and their long life. We also find silicone hoses used as vents, drains and so on in the engine compartments of post-'96 airplanes. Vacuum systems are using reinforced polyethylene hose. Lots of modern stuff, see?
I think thats exactly what I was saying, why use rubber when there are newer things available.
Too many people think that certified airplanes are so archaic that they still use old materials. I see modern polymeric compounds in newer airplanes all the time. They still use 5052 aluminum tubing aft of the firewall because it's far safer than using flexible hoses, is much cheaper, maintains its shape to avoid sags and low spots, and doesn't age nearly as quickly as polymers do. Fuels attack the compounds in flexible hoses and it's impossible to see internal deterioration until they fail, which results in the need for scheduled replacement. I use O-rings made of modern compounds, too, where specified.
Again, I think thats what I was originally saying....especially rubber.
The wiring used in airplanes is modern Tefzel stuff. A very thin, tough, teflon-based insulation, very fine tinned copper stranding in the wire, far greater quality than I've seen in any automobile. And it has been used for 4 or 5 decades. Cars need to catch up. There are still some areas where airplanes could use more modern technology: wheel bearing seals are an example. Modern seals are found on some new Cleveland wheels, but the design of some installations prevent their use. The whole wheel retention method would need to be changed for them to work. Gets expensive.
It may be a better type of wiring, but I think the wiring used in todays cars, and even much of the aftermarket wiring is available in very good quality,and is easily sufficient for aviation use. I'd venture to say that 99% of all homebuilt airplanes are not wired to Mil-Spec standards. For the most part, common connectors terminate most wires, so what good does it do to use Mil-Spec wire if you aren't using Mil-Spec connectors on the ends of them ? If a decent quality wire is utilized, properly assembled to a connector, and properly supported,there is no reason for it to fail. Most wires fail because of vibration, chafing,overloading, or improper assembly....not because the wire itself is somehow inferior to Mil-Spec wire. I think its great to find that something someone wants to use meets some Mil-Spec, but that doesn't mean it won't fail if its put in the wrong situation. When I was a buyer for Military components, the common understanding was that a Mil-Spec identifies the
minimum acceptable standard the government will accept. There are many products which exceed Military specifications, but we could not use them as a substitute for the specified item. Kinda like the fact that you can't upgrade many things in older certified airplanes with something newer and obviously better. Now, that being said, Military Specs are usually quite rigorous and you get a modicum of quality assurance with their use, and that gives everyone a feeling of confidence.....but you also need to use a little common sense as to whether there is something that will serve your needs better.
We had some electrical components which initially required 100% testing before installing in a weapons system. One particualr test was called "shake and bake". The components were put thru a torture test of heat and vibration before use. Then they were tested to see if they still worked and installed in the system. Kinda like buying a car that had been run thru a Baja Race and expecting it to be "good as new". Eventually they began to test a percentage of the components instead of 100% of them. A few random units were pulled from each batch and tested. Finally that evolved to just accepting units from a company because the units they supplied had a track record of doing well back when we actually tested them. Any new vendor had to get tests done and then we could use them as well. So, the question is, What is the best way to be sure something is of good quality ? The answer is, by how it does when you use it. Apparently the lower cost method worked fine because they still do it that way.
Mil-H-6000A 7 Jan 1960 (Original Standard)
Mil-H-6000B Supercedes Mil-H-6000A
Effective 22 March 1982
3.3.1 Inner tube. The tube of the hose shall be o seamless construction of suitable
synthetic rubber compounded with the necessary ingredients co meet the requirements of this specification.
3.3.3 Outer coating. The outer concing shall be predominantly
polychloroprene rubber compounded co meet che requirements of this specification.
Mil-DTL-6000 Rev D Supercedes Mil-H-6000B
effective 20 Sept 2007
3.3.1 Inner tube. The inner tube of the hose shall be manufactured from
synthetic rubber compounded with the necessary ingredients to meet the requirements of this specification
3.3.3 Outer coating. The outer coating shall consist of
polychloroprene rubber reinforced and compounded to meet the requirements of this specification.
