Aviator
Thanks a million fly2
Nothing on the website about what it costs if anything, whether the download is a demo or full version... needs more information.Hi guys,
if you're interested in wing sections design
you might want to know about this:
www.evolutiondesigns.eu
Best regards
========================================================================================================You are correct they don't. However, I suppose it could be argued that there are currently a number of good airfoils to use and there are independent researchers. You can see some of them in the list here: The Incomplete Guide to Airfoil Usage
One article I recall from about 30 years ago was in EAA's magazine: http://www.eaa.org/experimenter/articles/0909_archives.pdf
Dan Somers is now here: Airfoil design and aerodynamics by Airfoils, Inc
You can see this same airfoil {NLF(1)-0215F} designed by Dan Somers referenced in the chart here: Airfoil Selection
Harry Riblett's airfoils have been discussed on this forum before. You can see a book he authored on GA airfoils here: Design Books from Aircraft Spruce
There is another book on airfoils with articles from Barnaby Wainfan. Also on the second page there is a comprehensive book on airfoil sections.
David Lednicer (who worked for John Roncz) had some skepticism about Riblett back in 1988: Riblett airfoils (Walter Lounsbery, David Lednicer, "highflyer")
However, Riblett has also been discussed here on this forum.
What I've generally heard is that these types of airfoils pretty much do the job.
It's in the UIUC database and several others. Google works very well for finding airfoil data if you have the exact spelling of the designationThat first link you gave, listed the CGS Hawk Airfoil as, Univ Illinois UI-1720 How do I find the data on that, I would like to compare that to my T-Bird I.
Rich
I'm bumping this zombie thread because there are several programs mentioned and Daniel has just released version 1.10.0 of XoptFoilThere's a new airfoil design program in development called "XoptFoil". It uses a particle swarm algorithm to search for the optimum geometry based on the goals and constraints that you supply. This is a very computational intensive proses so it can tie up a multi-core machine for hours trying to find just the right airfoil section for your wing. Looks like it's only available as source code right now so you'll have to compile it yourself.
I tried XoptFoil for the first time a couple of months ago, and was very happy with the results. No magic there, but it sure sped up what I was trying to accomplish with plain ol' XFoil. I'll check out the new version!I'm bumping this zombie thread because there are several programs mentioned and Daniel has just released version 1.10.0 of XoptFoil
