Skypilot99
The RV-3 was built in 1975 and the engine is a lycoming 0-290 D2 engine with 140 hp. TT on the engine is 3200 hrs. and 558 SOH. The airframe has a TT of 1092 hrs. Both wings have had two wing mods done to it, the rear spar attach was mandatory and the wing spars have the thicker 3/16 spar blocks or plates for added strength. The instruments, radio and transponder are like new with TT of only 44 hrs. on them. Wiring is all connected to them and just needs to be connected to the engine and other electrical connections in the airframe like the fuel senders, battery, etc. Comes with an under the dash center console with 4 additional instruments and a location in the center for the fuel selector. It also has a top storage compartment with a top cover. New control stick grip and like new canopy cover by Bruces Covers, used only 8 times. New tires and wheel pants along with new style cowl cheeks. New performance wood prop and sky-tec starter. Most parts to get it flying again. Just needs a little work, some assembly, paint and should be ready to fly. If you need more info let me know. 573 888 7334
