Flywheel drive with starter on pulley end?
slociviccoupe
Apr 1, 2011
366
Palm Bay Fl.
Been done. As mentioned above buy the pulley with the steel bolt on center hub. Mount ring gear to that. Starter on the generator pad. Have to choose correct rotation starter. It matters its not just simple as swapping polarity.
As for flywheel end the old oem fkywheels are forged and very hard. Have one water jet cut down then turned on lathe to true it up. Drill and tap and now you have prop flange.
As for flywherl abd ring gear seadoo 787 has a nice ring gear and flywheel that can be remachined.
Mike von S.
Feb 4, 2021
43
Very helpful, thanks!
slociviccoupe
Apr 1, 2011
366
Palm Bay Fl.
I have the cut down type 1 flywheel that needs finish machined. Also have the seadoo flywheel. Id sell as no longer continuing project. Another benefit is you can run a mag cup and stator
Mike von S.
Feb 4, 2021
43
Not there yet, but thanks. I'll keep this in mind.
