Flying Wing to compete with the Jodel D9
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by erkki67, Feb 7, 2014.
  1. Feb 7, 2014 #1
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,516
    164
    Hello there
    A new Idea came up into my mind.
    The 30ies up to the 60ies was the time for big experiments in therm of aerodynamics and home building.
    The designs which could my interest are the following planes:
    - the Jodel D9 for the homebuilder and safe flying skills
    - BICh-20 a russian flying Wing flying on very modest hp
    - Payen AP-10 also a low hp airplane small with good Vs
    - Fauvel AV-60 a less successfull D9 competitor ( only 1 built)
    Just too sad that there has never been made a flying wing that could meet the following:
    - modern retrodesign
    - STOL
    - small, less then 5,5m in span
    - wooden built, with some use of foams but no composites
    - taildragger like the Jodel D11UL or similar gear, later retractable gear like Loehle 5151
    - sit in fuselage or sit on top fuselage
    - folding or detachable wingtips
    - being able to store in a 20' freight container
    - single, later 2 and more seater
    - open or enclosed cockpit
    - paramotor engined
    The following Parameters should be respected in order
    - safe and easy to fly
    - tough structure and gear for student and mountain flying
    - ultralight if possible
    - cheap to operate
    - cheap to build
    - easy to store
    - STOL
    - taildragger
    - foldable
    - high range as far as possible on 5Gal in the US and 20l in EU or more were possible.
    - high speed
    Is it too much of dreaming?
    :gig:
    Erkki
  2. Feb 7, 2014 #2
    12,835
    4,798
    I wonder if you could do a wooden version of Scott Winton's Facet Opal?
    BTW... Why would you need folding wings? Just turn the whole plane sideways for ground transport or hangar storage.
    Brian Clayton likes this.
  3. Feb 8, 2014 #3
    Alps
    Alps
    Alps
    Jan 16, 2014
    6
    3
    France
    What do you mean by high-speed ?
    Paramotor engined --> Wampyr-pelican ?
  4. Feb 8, 2014 #4
    planecrazzzy
    planecrazzzy
    planecrazzzy
    Aug 16, 2003
    330
    13
    Fangtastic
  5. Feb 9, 2014 #5
    Hugh Lorimer
    Hugh Lorimer
    Hugh Lorimer
    Feb 14, 2008
    298
    99
    Stair, Ayrshire, Scotland.
  6. Feb 9, 2014 #6
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,516
    164
    The facet Opal is a record braking little plane, outstanding performances, but not ideal for what I would like to use it.
    the Jodel D9 has some perfect habits I would like to find in tractor powered flying wing too.
    the landing gear must able to absorb not so perfect acres for landings.
    so, a pusher is not ideal.
    Hugh, I like your wing layout, but the fuselage should have the engine up in front and a taildragger gear similar to the D11UL, with a lot of suspension.
    a plane I really like is the Payen AP-10 or the Arup somehow, but still preferring the Payen.
    the Payen flew also on low horse power, which like, so now a days para motor engines could be used, so the airframe has to be light as possible.
    i believe in; less is more!
    erkki ;-)
  7. Feb 9, 2014 #7
    6,353
    2,224
    Almost exactly equivalent to a Jodel D.9 Bébé and with the same French accent was the Fauvel AV.60 Leprechaun (and related AV.61), see Charles Fauvel and his Flying Wings.
    Topaz and bmcj like this.
  8. Feb 9, 2014 #8
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,516
    164
    The AV-60 is indeed an interesting little bird, but do you know from we're to get construction drawings?
    bst rgds
    erkki
  9. Feb 9, 2014 #9
    autoreply
    autoreply
    autoreply
    Moderator
    Jul 8, 2009
    10,732
    2,540
    Rotterdam, Netherlands
  10. Feb 9, 2014 #10
    Aircar
    Aircar
    Aircar
    Banned
    Feb 20, 2010
    3,567
    367
    Melbourne Australia
    "moving prop up etc' --the problems created by moving the thrust line above the wing exceed any benefit from allowing nose up rotation and could even make trimming the aircraft impossible in the case of a tailless type -- the negative flap effect ( of back stick) will increase the actual take off speed which will of course reduce the thrust itself and slightly reduce the adverse thrust moment but not enough to be practical . A propellor half shrouded on the top side only will supply some nose up trim both by pressure field and inflow induced --the GM Lean Machine as once displayed at EPCOT (orlando) used this concept -the Terrafugia (Mk 1) suffered from the reverse and could barely take off even at 90 knots.
    The question has to be asked WHY specify a 'flying wing to compete' with a Jodel D 9 -- this presupposes some solution by being tailless or just arbitrary or capricious 'designing' . What is it about a D9 that is thought to be unsatisfactory? Is it the fuselage length perhaps? --why not then design a hinging or removeable rear fuselage (presumably for trailering or hangarage or something else ) --Quickie did this. Studying the shortcomings (bad pun...) of previous tailless aircraft might suggest a better way to retain the good features of a Jodel type but not repeat the mistakes on earlier untailed ones. The Stuttgart Uni FS 26 and Braunschweig SB 13 were good attempts to delete a tail end and some of the X planes apart from the less extensively tested Fauvel and Marske designs --unpopularity AFTER being available for a considerable time implies something UNsatisfactory about the untailed variety.
  11. Feb 10, 2014 #11
    6,353
    2,224
    No, sorry, I have no more info other than what was in the link.
  12. Jul 11, 2014 #12
    sigrana
    sigrana
    sigrana
    Oct 20, 2010
    12
    1
    Australia
    Scott was a good friend and we lost him. Besides any other consideration, the craft was a total handful to fly and worse to land. I would warmly advise you NOT to replicate it.
  13. Jul 11, 2014 #13
    Jul 30, 2005
    13,628
    5,277
    PIREPs of the Opal are notoriously hard to come by. Do you have any more information about this?
  14. Jul 11, 2014 #14
    11,532
    3,229
    Just enlarge a Bill Evans' Simitar model. For STOL flying wing you will need tons of horsepower to pretty much launch it.
