Float design safety
Discussion in 'Rules and Regulations / Flight Safety / Better Pil' started by Doggzilla, Oct 13, 2019.
  1. Oct 19, 2019 #21
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,047
    436
    Everywhere USA
    That’s not a bad idea guys. Foam has been added inside some existing aircraft wings because it helps with fluttering by stiffening the wings.
    In one case someone opened up the wing on their Hummel Bird to enlarge the tanks, and adding foam to the other sections to replace a lost cross member actually resulted in better flutter control.
  2. Oct 27, 2019 #22
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,534
    311
    Sydney
    That would be sodium metal- generates a lot of heat, Oxygen, Hydrogen and then goes boom!
    I would go for a large airbag deployed from the top of the cabin to lift the craft from the water.
    This has been done on some rescue boats and works brilliant- brings it back upright. For a aircraft just getting it above the water upside down would be ok.
  3. Oct 27, 2019 #23
    litespeed
    litespeed
    litespeed
    May 21, 2008
    1,534
    311
    Sydney
    Here is a self righting airbag for a rescue boat.
    Same principle but could be made lighter.
    [​IMG]
    vid of one in action
  4. Oct 27, 2019 #24
    10,050
    6,798
    Does that mean that they tested to a new, higher, Vd?
  5. Oct 29, 2019 #25
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,047
    436
    Everywhere USA
    I guess you could technically say that. He did test it up to something like 160-180mph without flutter (It was a far more powerful engine than stock, which was the entire reason he was hitting flutter speeds in the first place)
  6. Dec 28, 2019 #26
    PMD
    PMD
    PMD
    Apr 12, 2015
    76
    29
    Martensville SK
    not enough displacement in wings. I have thought about this for years (having lived a decade in the bush) and thought that something like an airbag under a blow-off panel near each wingtip would keep a float place from rolling over. Sadly, though, many sinkings happen when nose of floats are pushed below surface and tail goes over nose - when wing buoyancy would be of little help
