Flea style "Piojo Flying MiniBike"
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by FritzW, Oct 26, 2015.
  1. Aug 24, 2019 #361
    6,596
    5,376
    My vote is that the Piojo, if and when it becomes a real project, is absolutely the right candidate for tab and slot construction (if it has to be built in wood). And no round, laminated, or complicated "fiddly bits" should be necessary whatsoever. If a builder wants to add rounded laminated tip bows, and a leather stitched interior, then he or she can do that, but it's totally optional. A Piojo airframe should be able to be put together in a month or so using T-88 glue, and using Oratex the covering would take about a weekend. Another month MAX of engine mounting, misc. systems and control runs, fuel tank,etc. and you should be able to start taxi testing.
  2. Aug 24, 2019 #362
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    I'm still confused by the flea wing vs. free wing. So a free wing doesn't have, or need, any control? It's just free to pivot and find it's own "happy place" AoA? And the split Spraat wing is a free wing that's split on the center line and has independent pitch controls?
    If you can control a free wing why don't they use them on fleas so you don't have to hold back pressure on the stick all the time?
  3. Aug 24, 2019 #363
    6,596
    5,376
    You have to hold back pressure on the stick in a Flea at all times??? That would geet old pretty fast, speaking only for myself.
  4. Aug 24, 2019 #364
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    I saw it on a youtube video so it has to be true.
  5. Aug 24, 2019 #365
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,762
    190
    I can’t follow you, I’ve been flying with a Balerit, the HM1000, hands off.
    Power on and up it goes, power down and down it goes, with the wheel or stick you only ctl the speed.
  6. Aug 24, 2019 #366
    3,009
    1,713
    I guess logically it makes sense that on early fleas you must have had to hold a little back pressure at all times. Henri just had a single cable on the HM.14 controlling incidence and something had to have held it taut (there was no return cable, no spring, and no counterweight). At some point the plans changed this cable to a rod and all fleas thereafter used rods which makes it harder to tell when, if at all, this need for constant back pressure went away.
  7. Aug 24, 2019 #367
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    For some reason back in 2017 (on this thread) I knew that all fleas except the HM-1100 needed back pressure on the stick all the time. (it's a short thread with some good info, it's worth thumbing through)
    From post #46 on that thread:
    "The HM-1100 is the only "per the plans" flea that I'm aware of, that doesn't need back pressure on the stick. The wing was designed from the beginning to be controlled with tabs and there's no direct control linkage."
  8. Aug 24, 2019 #368
    erkki67
    erkki67
    erkki67
    Feb 18, 2010
    1,762
    190
    In fact, the Corduan or HM1100 had a Freewing controlled only by tabs.
    The HM1000, the Balerit had pushrods like almost all the fleas before.
    The first HM14 had only cables to control the incidence of the fwd wing, this feature and the overlapping caused in flight flip overs, which where not recoverable due to the cable control of the fwd wing.
    After the mod with separated wings and a new airfoil and pushrods instead of cables healed the bad habits of the Flea.
    Backpressure is only needed to achieve a certain airspeed, with all the fleas, except the HM1100.
    So a Piojo with split fwd wings would give it the cross wind capability and most probably, one of the safest little 3-axis flyer.
  9. Aug 24, 2019 #369
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    Does it need all three though? Fixed tailfins still leave it with pitch and roll control via the fore wing, which is enough and eliminates the control runs.
  10. Aug 25, 2019 #370
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,685
    377
    Sounds like a Spratt Piojo with split wings.
  11. Aug 25, 2019 #371
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    I don't think it's a question of "need", it's purely a "want". Ercoups fly fine, I just think they'd be a lot more fun with 3 axis control.
    Battler Britton likes this.
  12. Aug 25, 2019 #372
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    Is the hassle of splitting the wing less than the hassle of putting ailerons on the back wing? Would the split wing be positive control (linkages) or controlled with servo tabs? (maybe Bowden cables).
  13. Aug 25, 2019 #373
    6,639
    2,529
    Here is the Spratt patent. Looks pretty simple to me:
  14. Aug 25, 2019 #374
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    Compared to a regular 'ol aileron setup?
    And the wing pivot relying on the threads of two rod end bearings screwing in and out every time you move the stick. ...I dunno
  15. Aug 25, 2019 #375
    plncraze
    plncraze
    plncraze
    May 12, 2006
    1,685
    377
    The plans for the Spratt Controlwing are free on the internet. There are quite a few parts on it that you really don't want to fail. Even the Fleas have some "Jesus bolts."
  16. Aug 25, 2019 #376
    6,639
    2,529
    Yeah, that does 'look' more complicated but it is combining a V-tail style mixer with pitch and trim all in one mechanism. Separate out the needed functions and it looks simpler. But the part count may actually go up?
  17. Aug 25, 2019 #377
    Sockmonkey
    Sockmonkey
    Sockmonkey
    Apr 24, 2014
    1,729
    443
    Flint, Mi, USA
    The wing doesn't have to do three axis.
    Pitch and roll is fine.
    Look here.
    [​IMG]
    Most fleas have two rods controlling the fore wing so splitting it doesn't mean adding another rod.
    The Horten elevon setup would work fine for this.
    [​IMG]
  18. Aug 25, 2019 #378
  19. Aug 25, 2019 #379
    Speedboat100
    Speedboat100
    Speedboat100
    Nov 8, 2018
    859
    86
    Europe
  20. Aug 25, 2019 #380
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    And here's a recipe for banana nut bread. What does that have to do with the Piojo?
    Mcmark likes this.
