Finally: Cold Fusion Today! Cheap Energy 4 All!
Status
Not open for further replies.
E
Empirical
Italian scientists demonstrated a working prototype of a small "Nickel-Hydrogen" fusion reactor which produces 12.4kw (of heat) from 400w input, a gain of 31. It is stable, no radiation out of its shield and no nuclear waste!
10kw devices are going to market this year!
If this is 100% real (as it seems to be), then this is a major breakthrough in science and technology which will affect all areas, worldwide! There will be a huge boost to everything electric (including electric flying vehicles)! If this is prototype's efficiency, imagine what will come next!
Some facts (from this link):
* Regular Ni is used even though other isotopes may provide better efficiency. They think all the isotopes work to produce the effect.
* For some unknown reason
, not all of the Ni in the cell reacts with the hydrogen to produce energy. The percentage of the Ni that reacts is very low.
* Even though the percentage of the Ni that reacts with hydrogen is very low one kilogram of nickel powder should deliver 10 kW of energy for 10,000 hours. The consumption rate of hydrogen and nickel are 0.1 g of Ni and 0.01 g of H to produce 10 kWh/h. Note that for every picogram of nickel that is actually fused or reacts to the hydrogen, much more must be added. Not all the nickel added will react. So if you add 0.1g of Ni to produce
10kWh/h only a small fraction of that Ni will actually be utilized. When the device shuts off due to running out of fuel most of the .1g could be remaining.
* Tungsten is in no way used. However, "other elements" are used.
* Radiation is produced. However in the device demonstrated which is made for commercial use no radiation escapes due to lead shielding. The fact that radiation is produced is proof of a nuclear reaction.
* In the demonstration device for every unit of input there was approximately 37 units of output.
* A small percentage of th
e nickel is transmuted into copper. The amount of copper found in the cell is far greater than the impurities in the nickel powder. None of this copper is "unstable."
* There is no radioactivity in the cell after it is turned off. No nuclear "waste."
* All of the information needed to successfully replicate a self sustaining system is in the patent application (which is being held proprietary presently).
* The power density for thermal energy only is 5 liters per kilowatt.
* The hydrog
en has to be all hydrogen with no deuterium or heavy hydrogen. Apparently, any heavy hydrogen stops the reaction.
* This current system never goes below 6 times more energy out than in. During the test it produced 20 times more energy out than in. In the lab they have done similar tests and obtained 400 times more out than in, but it produced explosions.
Cold Fusion From Italy Nearly Commercial Ready | New Energy and Fuel
Status
