fibreglass fuel tanks !! whats the norm and what seems to be used ??
Discussion in 'Composites' started by tunnels, Aug 29, 2015.
  1. Aug 29, 2015 #1
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    china is my home , place of work but was born in N
    I am wanting to make fibreglass fuel tanks and want to know what is normally used for planes !! shape and size with or without baffles .The placement fillers and gauge mountings also what are the acceptable ways of venting .Fuselage mounted inside or wing mounted up hi and where ??
    I'm all ways being told planes are not boats even though so many things are done the same way !!
  2. Aug 29, 2015 #2
    Super Moderator Staff Member
    Oct 19, 2003
    6,004
    3,260
    Fuel tanks can go many place, and since they can have a huge influence on CG, must be part and parcel of the configuration.
    Wings are common places for them, being as you have a volume not particularly useful for people or bags and it is on CG. The safety argument goes on and on with proponents for both wing and fuselage tanks. The argument for wing type is the fuel is away from the people in a forced landing, with a downside that a forced landing with wing tanks will spill fuel on a nasty forced landing, making it unsurvivable. The argument for fuselage type is the cockpit should be designed to be sturdy enough to protect the humans, and including the tanks with them is going to prevent tank breaching in almost all survivable wrecks.
    In composite airplanes, integral tanks are the usual way. Epoxy tolerates straight gasoline and jet fuel just fine, but ethanol loaded gasoline can cause issues with some epoxies. I coated my tanks with fluoro-silicone from Dow-Corning just in case ethanol laden fuel is unavoidable. Vinylester resin is supposed to be proof against both heat and ethanol, but there are other issues with it.
    Cores that are in the same structures as fuels must be fuel safe. Gasoline will diffuse about and melt styrene foams that are in the same chunk of structure. PVC foam cores are excellent and make sturdy parts.
    JamesG likes this.
  3. Aug 29, 2015 #3
    9,731
    6,513
    Billski:
    What are the other issues that you are referring to?
    Thanks,
  4. Aug 29, 2015 #4
    Vision_2012
    Vision_2012
    Vision_2012
    Apr 21, 2010
    274
    122
    Shady Cove, OR
    Mr. Tunnels.
    Again, my advice is to buy a set of plans for a scratch built composite plane and study them.
    Or buy and read some of the books listed in the how-to file of this website.
    I'm sure there are people to answer this top post and summarize the process for you, but with a summary, what nuggets of info may be glossed over?
  5. Aug 29, 2015 #5
    BillM
    BillM
    BillM
    Feb 23, 2013
    140
    26
    Santee, Ca, USA
  6. Aug 29, 2015 #6
    Oct 19, 2003
    6,004
    3,260
    Vinylester resin is reputed to have some issues with secondary bonding. I have not looked into it further than just hearing that. Perhaps we could start a thread and get details.
  7. Aug 29, 2015 #7
    Sep 18, 2008
    4,872
    2,083
    I have used a fiberglaass tank, made with polyester resin, for almost 20 years with no leaks at all. It is way overbuilt and heavy, though, and repairing it would require using epoxy resin, since polyester doesn't bond well to old polyester.
    If I replaced it, I would use metal. No compound curves to it anyway.
    Dan
  8. Aug 29, 2015 #8
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    3,015
    2,013
    BDU, BJC
    HBA search function!! google bingelis!!
  9. Aug 30, 2015 #9
    foolonthehill
    foolonthehill
    foolonthehill
    Aug 30, 2015
    22
    21
    Morgantown, KY
    I build fiberglass fuel tanks every day. no gel coat, vinyl ester resin. One ply of veil, one ply of 1.5 ounce mat, one ply of 7500 cloth. That's it. It needs to be sloshed, and several componies make the right material for use with a composite fuel tank, but do make sure you use a product that specifically says "for use with fiberglass or composite" tanks.
    cheapracer and tunnels like this.
  10. Aug 30, 2015 #10
    Sep 18, 2008
    4,872
    2,083
    Sloshing is a bad idea for fuel tanks. It was frequently done years ago to stop weepy tank leaks, but inevitably some of it would peel off due to poor bond or simple age or alcohol in the fuel, and it would plug the tank outlet and cause engine failure. Randolph still sells sloshing compound "For Sealing Seaplane Floats Only" or something like that. Probably got sued several times.
    I wouldn't slosh even a new fiberglass tank with anything that has a chance of coming loose. Might be fine for a boat. My fiberglass tank was tight from the day it was made. Perhaps there is some magic stuff now that is guaranteed to stay put no matter what?
    tunnels and TinBender like this.
  11. Aug 31, 2015 #11
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    Thank you just what I needed !!
  12. Aug 31, 2015 #12
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    I was anticipating making the tanks in 2 halves and a inspection plate on to with all the pipes fitted and bolted on Its what's done with boat tanks but never seen anything here about doing it !!Good idea or not ?? never take any pipes out of the bottom they always fitted in the top!
  13. Sep 2, 2015 #13
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    For marine use I have always done the following !
    To save having to do secondary bonding just make each half in one go !!
    if you use the right glass it does not have to be a heavy lay up and end up a heavy tank ,
    heat curing I feel also is very important .
  14. Sep 12, 2015 #14
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    Does any one mount all there pipes and fuel gauge senders etc into a bolt on plate on the top of there tanks ??
    The same plate if big enough could be used to undo and take off to clean and inspect the inside of the tank maybe ??
  15. Sep 26, 2015 #15
    tunnels
    tunnels
    tunnels
    Banned
    Sep 7, 2014
    559
    21
    Sloshing AS YOU CALL IT should never have to be done if the tank is made properly and with some care and attention !! also layers of resin backed with VAIL is always a good safety measure ! There are special pigmented coatings resins that can also be used ! Personally seeing the fuel moving around in a tank is not and issue and is beneficial because im able to see how much fuel is still there ! As I have already asked about all services being in the top of the tank all fixed and welded into a plate on the top that is gasketed and bolted down !in the event of condensation or any sort of contaminate from dirty or stale fuel the plate can be removed for cleaning and inspection !! Spiral winding of continuous glass roving's makes a light and very strong tank ,also no sharp corners but every corner has a big radius !!
  16. Sep 26, 2015 #16
    Lendo
    Lendo
    Lendo
    Feb 7, 2013
    358
    56
    Brisbane
    Bill,
    I remember that thread, how did the paint go over that Silicone seepage?
    I've been trying to think of a way of eliminating that problem without any extra weight!
    George
