Facet Opel
Woodenwings
Aug 2, 2006
244
Toronto
Sorry if i missed this in the earlier comments. There is an aerodynamic problem with plank planforms. Might be good to dig a little deeper. Overcome that problem by passive or active means and you are laughing! I like the design....but would avoid it because it is bound to bite again. Sorry for being a downer!
Woodenwings
Aug 2, 2006
244
Toronto
If you are referring to tumbling then, if the designer is aware of the phenomenon, there are ways to mitigate.
Sadly no. Flutter of the self popagating and amplifying kind. All speed and load related. Better VNE warnings may do the trick. There is a good video about it somewhere on facetube.
addaon
Feb 24, 2008
2,342
Kanab, UT
Why would planks be any more prone to flutter than any other planform? If nothing else there are fewer surfaces to flutter so fewer critical frequencies in play.
8,764
For the small wings related to the Opal and the Pelican control surface flutter is the only real worry - and there well known ways to deal with that. These little wings are already pretty stiff due to the thick airfoils and low aspect ratio.
There are videos of higher aspect ratio flying wings developing span-wise resonance. Very different critters...........
11,410
small, indoor RC plank from years ago: up elevator would drive it into the ground.
Elevator portion of main wing chord too large, airfoil possibly had too much reflex, elevator throw possibly too large.
My friends and I flew a few of the old-time unswept R/C flying wings designed by Bill Evans in the 70's (Scimitar, Saracen, et al) and they didn't have those issues. Evans always used narrow chord "trailing edge stock" for the elevons, maybe 3/4 or 1 inch in chord. Easier to build was probably his reasoning. He was a character, and had a few cold solder joints in his head, but his airplanes almost always flew well (for the time) without any of the modern fancy transmitters and radios of today.
nestofdragons
Jun 8, 2016
819
Near Antwerp, Belgium
Thanks for reminding me not to overdo the elevons. I am thinking about making central trim surface and small enough elevons.
cblink.007
Jul 7, 2014
992
K2W6, Maryland, USA
It is not flutter per se, it is the very, very, very close CG/AC/NP proximity to one another that is inherent to the plank configuration, meaning that the pitch channel would be very sensitive, and could lead to divergence of the rigging & loading is not optimal.
This said, I do like the Marske wings; they have some very pleasant flying qualities.
Norman
Nov 28, 2003
3,312
Grand Junction, Colorado
This isn't flutter but is a problem unique to planks that modelers see often. They call it "hyperstall", apparently in the belief that there's separation occurring on the lower surface of the elevons. However droping the nose do to elevon stall would just make the separation worse so I have some doubt that that's actually it. This problem shows up when the CG is too far forward. What happens when static stability is too high and dynamic stability is low? Pitch oscillations are un-damped and the nose bounces up and down!
5,085
Probably all of the above, it was built by untrained eye. It was interesting to see the effects of the shortest possible tail moment when I’d feed in a little up elevator to flare and it would just splat down onto the gym floor. Surely not all planks do this, but the careless ones can.
It’s so easy to just slam together a quick foamie to play with and learn about the weirder configurations, isn’t it?
Norman
Nov 28, 2003
3,312
Well actually it's a common characteristic of planks. The elevator of a plank is NOT like an elevator on a stabilizer. When you pull back on the stick it reduces camber and increases the pitching moment. The reduction of camber causes an instantaneous lose of lift but the pitching moment takes a while to overcome inertia so there's a bit of a lag in pitch response. The result is that planks tend to translate downward a few feet while they're rotating to a higher AoA. Airplanes with tails don't do this because elevator commands don't change the wing's camber ie tailless aircraft don't have a tail moment.
Bill-Higdon
Feb 6, 2011
2,549
Salem, Oregon, USA
Thatone
11,410
A few years ago I actually asked Jim Marske about this phenomenon, after reading people's comments here on HBA. Now Jim is definitely not a "neutral party" (he's a strong proponent of his own product), but he said in no uncertainterms that his wings did not ever display that specific issue, and I believed him. His wings are not pure rectangle planks, and the reason for the tapered planform is probably to put the elevator further aft.
plncraze
May 11, 2006
2,267
Bill Daniels who flew some of Marske's planes with Jim said that Marske kept the longitudinal stability low to match the low inertia of a tail less aircraft. See Koen's Nest website "Theory of Flying Wings."
rotax618
Oct 31, 2005
1,663
Evans Head Australia
I was fortunate enough to witness Scott Winton fly the Facet Opal, and was a friend of his father, Col Winton. The Opal had pretty remarkable performance, but in my opinion was too pitch sensitive for the average pilot.
Planks do fly, some are more docile than others. If I were to design an unswept rectangular flying wing I would design for an AR of not more than 3.5, naturally if soaring performance is what you want a swept or Fauvel planform is best with a higher AR.
11,410
I recall there had been speculation about a change in the spar structure (cutting a hole for the oxygen bottle??) which severely degraded the capability of the spar to withstand G loads. The report referenced above indicated the wing was designed for 8G, but that may have been before a hole was cut in the spar. Is any of this speculation correct, or relevant to the loss of the aircraft?
