Experimental Placard
Discussion in 'General Experimental Aviation Questions' started by TXFlyGuy, Jun 10, 2019.
  1. Jun 11, 2019 #21
    Daleandee
    Daleandee
    Daleandee
    Sep 11, 2015
    824
    496
    SC
    If you have no option but to use the "experimental" lettering then you might find a way to conceal it in the open. Mine is quite visible when boarding but not quite as noticeable as it could have been:
    FWIW,
    Dale
    N319WF
    Hephaestus, bmcj and mcrae0104 like this.
  2. Jun 11, 2019 #22
    mcrae0104
    mcrae0104
    mcrae0104
    Oct 27, 2009
    2,858
    1,882
    BDU, BJC
    I suppose it could go on the belly of a Facetmobile.
  3. Jun 11, 2019 #23
    12,557
    4,581
    Without going to the reg (I’m too lazy to read it), what does it say about color? Can you hide the experimental label under the stab with subdued colors?
  4. Jun 11, 2019 #24
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    The reg doesn't say jack about color. But it does say:
    ...near each entrance to the cabin, cockpit, or pilot station...​
    however, so under the stab - don't think so. And I'd imagine that the DAR would want the lettering to be visible - you could say you painted it on with lemon juice, but... So some contrasting color that isn't a red-green colorblind test deal would probably be required.
  5. Jun 11, 2019 #25
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,391
    388
    Republic of Texas
    rep·li·ca
    /ˈrepləkə/
    noun
    noun: replica; plural noun: replicas
    a copy or model of something, especially one on a smaller scale.
    "a replica of the Empire State Building"
    synonyms: copy, model, duplicate, reproduction, replication;
  6. Jun 11, 2019 #26
    8,872
    5,728
  7. Jun 11, 2019 #27
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    Oh, for Cthulu's sake, read the f*cking regulation. Here's the relevant section, for those too lazy to look for themselves:
    ...or as an amateur-built aircraft and which has the same external configuration as an aircraft built at least 30 years ago...​
    The word "replica" doesn't appear. Does your plane have the same external configuration as a P-51 Mustang? No. it. does. not. Other than looking similar, having the big wing in the front and the little wing in the back, with an engine in the nose, it does not have the "SAME" external configuration. It's not the same size, it's not the same shape, it doesn't have the same control surfaces, it doesn't have the same canopy or cowling - all it has is stuff that LOOKS like a P-51, which is not the same as being the SAME external configuration as a P-51.
    My plane has a small wing in the front, a large wing in the back, and a pusher engine, but it sure as sh*t isn't a Wright Flyer.
  8. Jun 11, 2019 #28
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,143
    426
    Despite your adamant assertion, reg's are still often "interpreted". My Eindecker isn't an identical replica. I approached my DAR about using small 2" N numbers (edited to correct size) and he agreed that my plane did have the same external configuration as the original and that I could use the small numbers.
    When he came to inspect an FSDO rep came with him and didn't have any concern about the size of the numbers.
  9. Jun 11, 2019 #29
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,391
    388
    Republic of Texas
  10. Jun 11, 2019 #30
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,143
    426
    Yeah, I misspoke. I meant to say that my plane has 2" numbers instead of 3".
  11. Jun 11, 2019 #31
    Sprucemoose
    Sprucemoose
    Sprucemoose
    Nov 2, 2008
    111
    62
    Milwaukee, WI
    That makes more sense. I sport 2” NX numbers and no EXPERIMENTAL signage. But I complied with the strict letter of the law to do it, which is an important point in this discussion.
  12. Jun 11, 2019 #32
    radfordc
    radfordc
    radfordc
    Feb 5, 2008
    1,143
    426
    I feel that I did, too. And my DAR agreed.
  13. Jun 11, 2019 #33
    Sprucemoose
    Sprucemoose
    Sprucemoose
    Nov 2, 2008
    111
    62
    Milwaukee, WI
    I think the OP should get in touch with your DAR! Sounds like yours is a similar situation and it worked out in your favor.
  14. Jun 12, 2019 #34
    TXFlyGuy
    TXFlyGuy
    TXFlyGuy
    Apr 26, 2012
    1,391
    388
    Republic of Texas
    We did contact a local DAR here. He said we are good to go with the NX15180, and omitting the EXPERIMENTAL placard.
    bmcj likes this.
  15. Jun 12, 2019 #35
    Sprucemoose
    Sprucemoose
    Sprucemoose
    Nov 2, 2008
    111
    62
    Milwaukee, WI
    Good news and glad it worked out for you.
  16. Jun 12, 2019 #36
    Marc Zeitlin
    Marc Zeitlin
    Marc Zeitlin
    Dec 11, 2015
    424
    571
    Tehachapi, CA
    So I'd like to apologize and say that obviously, I was wrong. My interpretation of the rules clearly doesn't line up with at least one DAR's interpretation of the rules, and their's is the one that counts. I'm glad you were able to <without fudging> get the plane to look like you wanted it to look. I will attempt to turn down the "stridency" knob in the future, to something less than 11.
    mcrae0104, TXFlyGuy and BJC like this.
