Experimental Limitations
Backwoodsman Pilot
Aug 6, 2008
Hello
I have a couple of questions pertaining to experimental aircraft.
1. If a pilot currently has a commercial license, can he be compensated while flying an experimental aircraft?
2. Can an experimental aircraft be used to log flight hours (PIC) towards a private, or commercial rating?
My thoughts were to fly an experimental aircraft after I get my private certificate to log solo hours toward my commercial certificate.
Blessings,
Mark
9,435
1, no, well, I guess a test pilot gets paid to fly an experimental aircraft, and you can pay a CFI to instruct you in your own experimental, but you can't use it to train others or carry paying passengers.
2, yes.
-Dana
Press any key to continue or any other key to quit...
9,435
A lot of pilots get payed for air shows flying experimental airplanes.
Yes, as long is you're not "carrying persons or property for compensation or hire" I guess it's OK. But that's kind of a limited market.
-Dana
Resist militant "normality" -- A mind is a terrible thing to erase.
Backwoodsman Pilot
Aug 6, 2008
Dana and Joe,
Thank you for your replies. Right now I am waiting on my ground school course. It's been 20 years since I went through ground school and I'm looking forward to getting my private certificate and other ratings. I've been looking at homebuilts since 1999 and still haven't decided on which kit to buy. :)
Blessings,
Mark
mcjon77
Aug 5, 2008
205
CFIs can get a special exemption from their local FSDO to be compensated for providing flight instruction in their airplane. Usually this involves providing transition training for pilots new to the airplane.
Example:
You are a CFI and you own an RV-8. You can apply for permission to give others flight instruction in your RV-8. This is especially valuable when an insurance provider requires that a new RV-8 owner receive some kind of transition training before they will sign off on the policy.
Rhino
Apr 8, 2004
771
SW Ohio
Depends on the category. There is an experimental exhibition category too. Those are mostly warbirds, and I imagine they have a somewhat decent market for that.
9,435
All the RV's except the RV-12 are E-AB. E-AB limits are whatever the builder says they are when he applies for the airworthiness certificate. LSA limits are 1320 lbs gross weight, 120 knots max, 45 knots max stall speed, two seats, single engine, fixed gear and prop.
-Dana
Be Politically Incorrect: Support the Constitution!
9,435
E-AB = Experimental-Amateur Built... your basic homebuilt airplane, where anything goes (as opposed to E-LSA, Experimental-Light Sport Aircraft, which can only be built from an approved kit with no modifications).
-Dana
Aviation has made the world a lot smaller, but it's still hard to miss it if you fall.
13,532
... you can pay a CFI to instruct you in your own experimental, but you can't use it to train others or carry paying passengers...
I think Dana is right here and addresses what you are really asking. If you buy an experimental, you can pay an instructor to give you instruction in that plane (note that some instructors choose only to instruct in certified aircraft, so you may have to look around a bit).
As always you should look to the written regulations (or ask the FAA) to confirm this.
Bruce :)
Rhino
Apr 8, 2004
771
SW Ohio
At this point the RV-12 is also E-AB, and LSA eligible. Vans hasn't yet gotten approval to offer it as an E-LSA aircraft. It is currently available as an E-AB, and likely still will be after it is also offered as an E-LSA. There are advantages and disadvantages to both types. Vans discusses that on their RV-12 page.
Van's Aircraft - Aircraft Models: RV-12 Introduction
rpellicciotti
Feb 10, 2005
43
Aircraft in the Experimental Exhibition category cannot carry passengers for hire unless they have a waiver. Some large organizations (EAA, CAF, others) have these waivers.
Latest posts
