Experimental Ducted Fan Aircraft Designs
copec
Aug 2, 2015
47
Santa Clara, UT
=Duseks (M-18 30 HP,21 kg opposite) Duct (rigid carbon )+Fan (550 mm) weight is circa 10 kg...
(the "semisoft" duct can be much lighter)=no risc to contact blade with duct surface !
I'm interested in a custom motor rim drive ducted fan, like the water propulsors:
copec
Aug 2, 2015
47
Santa Clara, UT
=big diameter stator is heavy and costly...
Very good point!
Theoretically as the circumference grows, the flux is spread over more area and is less dense as with the amount of corresponding ferromagnetic material. In a practical sense I doubt the same weight could be kept and it would be substantially heavier as you point out.
dog
Dec 29, 2019
276
Bille mentioned using carbon for the windings in an electric motor and also they would be the structure.
This is bieng done now experimentaly with carbon
nanotube yarn replacing copper, with very good preliminary results.
Bille Floyd
Sep 26, 2019
201
Very good point!
It's called , "functional fixedness"
bias in problem solving because you have already bin given
a solution ; and now you only see that one solution, with the exclusion
of all other avenues.
That , (Less dense) you described ; it needs to be redirected
and focused at a better angle. And your not just limited to both
sides ; you have top and bottom of each stator core, as well
when ya add a slight bend.
The cylindrical magnetic core , can also be wound ; doesn't
have to be a earth magnet. Now you need a computer, to
keep everything in phase.
Bille
@ dog :
That was an Awesome post !!!!... ...
dog
Dec 29, 2019
276
today C< Al<Cu<Ag ... but Conductivity/ Weight = Al > Cu !!!
but tomorrow? probably...
Agreed, tomorrow.
Very interesting to think of motor structure, C + epoxy, as also conductor, so some potential for
weight saving, smaller size,less parts count.
The things that make a good machine.
henryk
Mar 8, 2010
5,154
krakow,poland
BUT !=
=rotating motor with rotating propeller(s) can generate <10 kG thrust/kW +noise + safety problems !
=flapping (OSCILLATING) thrusters are as minimum ONE ORDER better,>100kG/kW !!! +lower NOISE +allmost SAFE for enviroment...
henryk
Mar 8, 2010
5,154
krakow,poland
BTW=it exist EJECTION fenomenon...
=it is possible to gain thrust force,aspatially at climbe phase !
-any info,knoulage ?
