experiamental fighter jet style aircraft
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by T-51ls1, Dec 7, 2012.
  1. Dec 30, 2012 #201
    topspeed100
    topspeed100
    topspeed100
    Banned
    May 4, 2009
    4,063
    63
    Oulu/Finland
    You are quite right..only the middle one ( twin fan outboard engined ) has been developed further...and indeed there is a change made to lift the engines higher to cleaner air further from the vertical ( albeit not sure how far it ought to be from it ). My last design was a tractor model in classical style ( very conservative ).
    I am impressed by your expertize and keen observation...reading is always good thanks for the advice.
    14756d1322498701-my-130-pounder-twin-engine-aerobatic-speedster-aaa1_fnxiihigh_e35.jpg
  2. Dec 31, 2012 #202
    topspeed100
    topspeed100
    topspeed100
    Banned
    May 4, 2009
    4,063
    63
    Oulu/Finland
  3. Jan 1, 2013 #203
    PaulS
    PaulS
    PaulS
    Sep 6, 2011
    297
    12
    Seattle, Wa., USA
    Topspeed,
    Pulse jets are not capable of supersonic speeds.
    Their design limits their speed to 3-400 mph regardless of the amount of thrust developed.
  4. Jan 1, 2013 #204
    topspeed100
    topspeed100
    topspeed100
    Banned
    May 4, 2009
    4,063
    63
    Oulu/Finland
    I see...I tought a ramjet is sorta like a pulse jet ?!
    How fast could two of the fastest ( most thrust ) model jet engine take you ?
    Jet Powered Bicycle - YouTube
  5. Jan 1, 2013 #205
    PaulS
    PaulS
    PaulS
    Sep 6, 2011
    297
    12
    Seattle, Wa., USA
    I could insert any answer here but any answer I gave would only be correct in a very limited way.
    Your speed will depend on drag more than anything else but acceleration will depend on thrust.
    Ultimately drag, pounds of thrust, weight and velocity of exhaust will be the determining factors for speed.
  6. Jan 2, 2013 #206
    13,087
    5,012
    No, a ramjet (like the turbojet) has a continuous combustion process.
  7. Jan 9, 2013 #207
    topspeed100
    topspeed100
    topspeed100
    Banned
    May 4, 2009
    4,063
    63
    Oulu/Finland
    I think I got it now..here fitted with these might take you there ( 400 mph + ); PBS Velká Bíte
    First thought about the twin AMTs..but these have 450 lbs thrust now.
  8. Jan 10, 2013 #208
    topspeed100
    topspeed100
    topspeed100
    Banned
    May 4, 2009
    4,063
    63
    Oulu/Finland
    Slight fine tuning...still twin tail wheels..are they ok ?
    Tail wheel dia is 120 mm.
  9. Jan 10, 2013 #209
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,109
    312
    Northern Illinois
    120mm is very tiny. And probably only acceptable on perfectly manicured runways. A 120mm wheel might not clear a speedbump. While that design does address some of the tipover problems, you're still going to run into all sorts of other issues. Such as the torque that would come from a small crack in the road.
    This is very much one of your less crack-pipe inspired designs. I think that one might actually work.
  10. Jan 10, 2013 #210
    topspeed100
    topspeed100
    topspeed100
    Banned
    May 4, 2009
    4,063
    63
    Oulu/Finland
    Thanks nerobro...I have to take this as a compliment. I also have a haunch it might work...as a canard it has just right geometry ( or the shape is following the guide lines of a good canard design literally )...I only wish Orion was still here to comment.
    I looked for luft46...and only Gotha and Messerschmitt seemed to have ever considered a canard...dr. Focke's friend mr. Wulf died in an canard accident. Then again Wright Bros flyer was a canard...and Stefanutti has made his SS2 already in 1937.
  11. Jan 14, 2013 #211
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,109
    312
    Northern Illinois
    The wright planes were not very stable in pitch. They had most of their weight carried by the main wing, so the stabilizing forces were small. John Rocz says a "good" canard has roughly half the wing load on the canard, and that leads to a stable, un-stallable setup. It looks like you've got a design that's ment to carry a lot of the weight on the canard. That's good.
    Good luck. I still want to see you make something.
  12. Jan 14, 2013 #212
    Super Moderator Staff Member
    Apr 4, 2007
    8,777
    3,139
    The Wright planes weren't just "not very stable in pitch"; they were downright unstable, to the point of being dangerous. Then as now, though they didn't understand it back then, an aft C.G. is bad.
    I can't see needing to put half the load on the canard; then you're into tandem wing territory... which is fine if that's what you're after. For a "conventional" canard (is there such a thing?) what matters for pitch stability is that (like any aircraft) the dCm/dα for the whole aircraft is negative.
    -Dana
    The United States was formed to protect liberty. It now has a major party that is afraid that someone, somewhere, is doing something without permission.
  13. Jan 14, 2013 #213
    13,087
    5,012
    This statement leaves itself open to interpretation...
    Does it mean:
    1) The canard carries 50% of the aircraft weight, OR
    2) The canard carries half the amount of weight that the wing carries, OR
    3) The canard is loaded at half the load per square foot compared to the wing?
    DangerZone and ultralajt like this.
  14. Jan 14, 2013 #214
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,109
    312
    Northern Illinois
    He says most successful canard designs carry half of the load on the canard. 50% of the aircraft's weight. The canard is intentionally heavily loaded, so it stalls long before the main wing.
    No kidding. It's also not just "aft CG", aft CG can be ok, ish.. if that's what you're aiming for. But they were also very close coupled adding to the problem.
  15. Jan 14, 2013 #215
    13,087
    5,012
    I don't know if I subscribe to that theory. Borne weight affects the stall speed of a surface, but not the stall angle of attack. Canard design should be such that the incidence angles of the canard and wing be set relative to each other so that the canard reaches its stall AOA before the main wing. A heavier loaded canard will provide a smoother ride (less disturbance from gusts), but it will have no bearing on the canard stalling before the wing. It may, however, increase your minimum speed.
  16. Jan 14, 2013 #216
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,109
    312
    Northern Illinois
    *shrugs* I'm a proponent of conventional designs versus canard. I also prefer stickshift, and motorcycles. John Rocz knows what he's doing. :)
  17. Jan 14, 2013 #217
    Apollo
    Apollo
    Apollo
    Feb 7, 2010
    301
    197
    Southern California, USA
    The Long-EZ, Cozy and similar derivatives carry 21% to 24% of their gross weight on the canard. Their canards are approximately 15% of the main wing area, so the canards have a wing loading that is about 50% higher than the main wing. Depending on the CG location and relative sizes of the main wing and canard, many configurations are possible. As Dana said, if the canard is carrying 50% of the gross weight, you will be in tandem wing territory. The front wing (canard) of Quickie style aircraft carries slightly over 50% of the gross weight.
    topspeed100 and DangerZone like this.
  18. Jan 14, 2013 #218
    12,494
    2,525
    Indeed.
    The Wrights early airplanes ( all canards) had the neutral point ahead of the C.G. Very bad indeed.
    The 1911 Wright Model B eliminated the forward surface and placed the tail in the back. This put the neutral point aft of the C.G. and all was well.
    This and more is explained in the book: The Wright Brothers as Engineers, An Appraisal by Quentin Wald.
  19. Jan 15, 2013 #219
    Starman
    Starman
    Starman
    May 17, 2009
    2,011
    61
    High in the Andes Mountains
    I think that when the canard carries half the weight that it's 'good' because you have less total wing area. It's also good because the CG shifting front to back is further from both wings and so therefore the plane has a greater CG range. If the CG is closer to the rear wing a small shift in CG puts a much greater change in the load on the canard.
  20. Jan 15, 2013 #220
    Apr 4, 2007
    8,777
    3,139
    Only if the canard is large enough to carry that weight at or close to its max L/D in cruise. Otherwise you lose the theoretical advantage of canards, i.e. reduced trim drag.
    -Dana
    The first rule of intelligent tinkering is to save all the parts.
