flat6
An oil condition sensor is badly needed for any kind of reliability.
Seems like thread drift to me, but I gotta ask: What would this sensor observe, report, etc? And how does this relate to a seal coming out and dumping engine oil?An oil condition sensor is badly needed for any kind of reliability.
An oil condition sensor is an online monitor. It tracks metal debris trends and can signal a warning just before a catastrophic failure in the engine. Either before tackoff or during flight. In latter case The pilot can then turn down power and look for a place to land. Engine conversions with no benefit of long term tests in an engine dyno will need this. Specially highly tuned ones.What's wrong with regular sample analysis?
Does the product exist? Sounds worthy of its own topic. Want me to establish a new thread and put this on it? I have info that will contribute...An oil condition sensor is an online monitor. It tracks metal debris trends and can signal a warning just before a catastrophic failure in the engine. Either before tackoff or during flight. In latter case The pilot can then turn down power and look for a place to land. Engine conversions with no benefit of long term tests in an engine dyno will need this. Specially highly tuned ones.
Since we have methods of measuring these in real time is there really enough variation in service life of the oil under different operating patterns to warrant this kind of monitoring?They probably should also have a means of watching viscosity vs temperature, acid and water content of the oil in order to warn that an oil change is needed,
Dan has put this one thorough the stadium lights!This is a solution in search of a problem.
Too many folks want technology to do all their thinking for them. It's one of the reasons why airplanes are getting too expensive to buy and maintain. Fancy systems cost money to install and fix. Oil pressure and temperature tell us a lot if we know even a little bit about engines. Checking the filter during an oil change tells us a bunch more. Neither of those is expensive and they're not failure prone and don't add needless weight and complexity.
Please cite products that are real time, suitably accurate, reasonably priced, and long lived in the engine sump for acid and viscosity so that we could use them.Since we have methods of measuring these in real time is there really enough variation in service life of the oil under different operating patterns to warrant this kind of monitoring?
I agree, but a monitor would need recognize a bunch of oil failure modes, including viscosity shifts, acid increase, solids accumulation recognizing abrasive quality and particle siz. Tall order when just changing the oil at regular hour intervals works so well.Simply changing the oil every XX hours/miles seems to have proven to be reliable and economical..........with regard to oil service life.
Yes, it might be nice to have such a device, but it wouldn't be cheap and it wouldn't weigh nothing and it wouldn't stop the degradation of the oil itself and it sure wouldn't compensate for a pilot's carelessness. It would, 99.99% of the time, tell us, at around 40 or 50 or 60 hours, that the oil needs changing.Please cite products that are real time, suitably accurate, reasonably priced, and long lived in the engine sump for acid and viscosity so that we could use them.
Will they really offer any improvement over a conservative oil change interval? Probably not...
I know of none that currently meet all those parameters. Real time and suitable suitably accurate? They do exist. I've used them in the oil field. Inexpensive they weren't and I can't say they would survive at the temperatures needed........ but I suspect they could be adapted.Please cite products that are real time, suitably accurate, reasonably priced, and long lived in the engine sump for acid and viscosity so that we could use them.
Show us the need. Please cite engine failures in flight that can be attributed to oil problems. We have plenty of maintanance cases of rusting cylinder walls and camshafts, swallowed valves, separated heads and thrown cylinders., but I just do not recall engines failing in flight from anything resembling used up oil...An oil condition sensor is badly needed for any kind of reliability.
Right. They usually just wear out sooner. Compressions and oil pressure start to fall off, oil consumption goes up, sparkplugs get fouled quickly. The typical stuff that's supposed to be caught at annual inspections.but I just do not recall engines failing in flight from anything resembling used up oil...
