Please inform us all via a separate thread what the two of you are on about. Those look like Azusa 6 inch Tri-Star wheels.To prevent further dilution of the thread, I have sent you a PM, sir.
Is that the Longster that Leon York built?DD 1835 is hard to beat. My Longster, which is a very close comparison to a Headwind (EW, wing area, useful load) does very well with my Low Aspect Ratio (read: oversize) self, in hot West Texas.
I just want to see the fight.
No you guys got it all wrong... I was just smarmiliciously pointing out that the airplane would look a whole lot better with appropriately proportioned wheels and tires on it. Ain't no major personal or theoretical disagreement going on here....
It would need motorcycle type wheels to be period correct.
Kyle, I worked with Don back in the 90s helping clean up his drawings to what you get today. Don would probably recommend the use of a VW with the Maximizer. He has stopped advertising now but when he did he always used a picture of the Geide Headwind which had a Maximizer as he felt it best represented the Headwind.
Don is a class act guy. I managed to pull some strings and got him a tour at LM when the F22 line was running. He later sent me copies of the Headwind, Maximizer and his Foo Fighter.
So are you really building a Headwind??
Heavy duty spoked bicycle wheels maybe 12-16” would work and look period correct, actually better for any kind of grass field operation.
Thank you!1200 cam ? Stock cams on the 1200 cc, 40hp,-- 1300 cc, 50Hp--- 1600cc, 60 HP are all the same. Different cam gear on the same came after 1971, I believe. Stock cam is hard to beat for low RPM torque.
Going from a 60" dia to a 62" dia x 26" pitch is a bit much for the 1835cc engine. I wouldn't go more than the 24", maybe a 22" if you wasn't concerned much about the speed. Could try the 62" dia x 26" and if it was to much load on the engine , you would be able to reduce the dia a littl at a time to suit.
I have cruised my 1835 cc engine at 2500 rpm with a cruise speed of about 65 mph, but couldn't get the oil temp up over about 160 F . Doing that on a cross country flight trying to say back with 2 Piets with A-65's. Summer day.
Fuel burn would be about 2.5 gph. Just a guess.
