Aesquire
N
In the teeter totter /see saw pitch stability Analogy, the Center of Gravity is in front of the Center of lift, ( on most "normal" airplanes w/out unstable fly by computer ) pulling the nose down. The tail pushes down ( or canard up ) to counter balance the offset. The pivot in that calculation is at the Center of Lift.
The important thing is that the pull of gravity doesn't ( noticeably ) change, while the tail force varies with airspeed.
One approach to making a "stall resistant" aircraft is to limit tail size so it can't hold the nose up at speeds and ( the related but not fixed ) angles of attack high enough to stall. ( in level flight ) This works, but has consequences. It makes for a lousy bush plane, since you can't slow down all the way to stall in unaccelerated flight. ( but can in a dynamic maneuver like a zoom climb ) Don't know any contemporary designs in production that use that "trick", but it was used in some 1920-30s "Safety Plane" competition designs.
Thank you. To clarify, the Center of gravity indeed is where the plane rotates around in flight.To add to Aesquire's post: the wings center of lift isn't the pivot point. The aircraft's center of gravity is the pivot point. But, other than that, his premise is quite correct.
