Enclosing an Evans Volksplane VP-2
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by cluttonfred, Oct 26, 2014.
  1. May 18, 2019 #121
    Wanttaja
    Wanttaja
    Wanttaja
    Sep 15, 2013
    1,342
    1,567
    Seattle, WA
    A nearly five-year-old thread? You're lucky that AIRPLANES are still being discussed.....
    Ron Wanttaja
  2. May 18, 2019 #122
    10,242
    6,964
    Apparently there are plenty of used Zenith fuselage skins that can be repurposed to enclose a VP-2.
    akwrencher likes this.
  3. May 18, 2019 #123
    Turd Ferguson
    Turd Ferguson
    Turd Ferguson
    Mar 14, 2008
    4,916
    1,821
    Upper midwest in a house
    I miss some threads the first time around so I'm glad they get dragged back out.
  4. May 19, 2019 #124
    3,010
    1,714
    I was sure I had some relevant pics to add but I can’t seem to find them. Anyways, I think the one to copy is a red and yellow VP-2 that I’ve actually seen two full size human beings fly in on a summer day. It’s Canadian registered but I can’t remember what the registration was. In any case, I’ve seen it at the UPAC fly-in in southern Ontario so it must be based a reasonable flight from there.
    cluttonfred likes this.
  5. May 19, 2019 #125
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    To enclose a VP almost seems like a sin.
    ultralajt and FritzW like this.
  6. May 19, 2019 #126
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    I would build a greenhouse similar to that on the Fiesler Storch but with fewer angles and pieces. Extending the line of the stock design windscreen to an appropriate height for head clearance, flat to past the seat back and angled down to the fuselage from there, so just two angles from the side profile. For top profile build a flat ledge at the top of the fuselage appropriate for shoulder room and angle it back to the fuselage for and aft in lines consistent with the angles of the side profile so the top profile would have two angles on each side. Then front and rear would be draw straight lines to join side and top corners. Flat everywhere is consistent with the rest of the plane.
  7. May 19, 2019 #127
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    Not if it's done ugly enough to be "cute".
  8. May 19, 2019 #128
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    I found two babies on my door step this morning. One of them is a VP-2 fuselage built from the ground up to be enclosed. The cockpit bulkheads haven't been rounded off and the ply side skins go all the way to the top, even in the turtle deck area.
    An interesting side by side shot of a 24' wide VP-1 (2" wider than the plans) and a standard width VP-2.
    cluttonfred and blane.c like this.
  9. May 20, 2019 #129
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
    Pops and cluttonfred like this.
  10. May 20, 2019 #130
    Riggerrob
    Riggerrob
    Riggerrob
    Sep 9, 2014
    1,261
    372
    Canada
    The fuselage skin flexes in and out ........ oil-canning ........ until it develops cracks, wrinkles and smoking rivets.
  11. May 21, 2019 #131
    Little Scrapper
    Little Scrapper
    Little Scrapper
    Jan 3, 2014
    5,397
    3,318
    Wisconsin
    I belong to the builders groups and I've never heard this mentioned. There's a ton in service, I find this odd they would wear out.
  12. May 21, 2019 #132
    Twodeaddogs
    Twodeaddogs
    Twodeaddogs
    Jan 18, 2009
    838
    238
    I did the first flights on two new build 601 HDs and it was a bit unnerving to see the wing skin flexing before it settled down. When you compare it, say, the skin on a PA-28, which appears to be cut from the Brooklyn Bridge. The skin on the turtledeck flexes like a biscuit tin and they warn you not to press down on it when climbing aboard. The second one of the two had the most annoying creaks and groans from the undercarriage until we lubricated it thoroughly and machined and fitted an extra nylon sleeve for the noseleg to slide in. If you flew them without a headset, you could hear the airframe flexing (oil canning) and I also flew a 601 XL, whilst wearing an expensive Bose headset, and it oilcanned at a frequency that could be heard over the headsets ANR ability. The aircraft looked perfectly fine on the ground. The 701 and it's copies (Citius, Savannah) appear to have more rigid airframes.
  13. May 21, 2019 #133
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    I don't think "cheap and easy" wears out any faster than "expensive and tedious". ...the humble Volksplane is a perfect example. IMHO the 601 is "just good enough" more than "cheap and easy".
  14. May 21, 2019 #134
    3,010
    1,714
    That’s probably a much better way to put what I said, though there is still an awful lot of overlap between cheap and good enough.
  15. May 21, 2019 #135
    6,886
    2,522
    Tiger Tim, I don't know about a red and yellow Canadian VP-2 but there is a Subaru-powered white one with red and blue stripes that caught my eye. I have corresponded with Jim Scoles, the original builder.
    Fritz, do you know the story behind the VP-2 fuselage? Was the idea to enclose it or was it just about taking "KISS" even further by making the bulkheads simple rectangles?
    blane.c, the Baker Supercat is very cute and can pull off that canopy well as a cartoon version of an ag plane, but on a VP-2 the straight lines would restrict the already tight cockpit to single-seat use. The only way I have come up with to enclose a VP-2 and keep some elbow room is a bulged canopy like a WWII Malcolm hood.
  16. May 21, 2019 #136
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,290
    1,476
    Marion, Ohio
    Maybe for an aluminum skin. But the VP is made of plywood.
  17. May 22, 2019 #137
    FritzW
    FritzW
    FritzW
    Jan 31, 2011
    3,750
    3,362
    Las Cruces, NM
    It's definitely so he could enclose it. I'm not exactly sure what he had in mind for the canopy/cabin (I think it was going to be more of a Piper Cherokee'ish cabin with a T top).
    Rounding the bulkhead corners is such a non-event you wouldn't leave them square just to keep things simple.
  18. Sep 27, 2019 #138
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    3,807
    678
    capital district NY
  19. Jan 4, 2020 #139
    6,886
    2,522
    Old thread...new question for anyone with experience with blown canopies. Is it possible/practical to do a blown canopy that is bulged wider than the canopy rails at the sides to provide more elbow room? Something like this?
  20. Jan 4, 2020 #140
    7,505
    6,495
    Several years ago I was at a fly-in at Wynkoop airport ( 6G4) , OH and this airplane flew in from Maryland. They don't come any better than this one. Talked to the owner for a long time about the airplane. Very, Very nice.
