Electric by Stretching Action
Discussion in 'Electric Propulsion' started by RonL, May 23, 2019.
  1. May 23, 2019 #1
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
  2. May 23, 2019 #2
    7,235
    2,069
    Sound like a generator to me. Which means you'd need to wind it in flight. A motor to wind it so it can run a motor?
  3. May 23, 2019 #3
    Aerowerx
    Aerowerx
    Aerowerx
    Dec 1, 2011
    5,223
    1,444
    Marion, Ohio
    Uh, no.
    The way I read it is that all you need is a bottle of water and some table salt.
  4. May 23, 2019 #4
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
    I would think the motor could be built into the prop hub, or between the prop and band, continually keeping a tension between two values. It would cycle in the same way a shop air compressor works between two air pressure set points.
    250 watts per Kg seems impressive, but I'm not sure how 30 stretch cycles per second would work, or how expensive it will be.
    A sealed tube with about 200 pounds of yarn and enough salt water to saturate it?
  5. May 23, 2019 #5
    7,235
    2,069
    But where are you getting the power to stretch it?
  6. May 23, 2019 #6
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
    "In order to generate electricity, the yarns must be either submerged in or coated with an ionically conducting material, or electrolyte, which can be as simple as a mixture of ordinary table salt and water. Fundamentally, the yarns are supercapacitors. In a normal capacitor, energy — like from a battery — is used to add charges to the capacitor. In the new method, when the carbon nanotube yarn is inserted into an electrolyte bath, the yarns are charged by the electrolyte itself; no external battery or voltage is needed.
    When a harvester yarn is twisted or stretched, the volume of the carbon nanotube yarn decreases, bringing the electric charges on the yarn closer together and increasing their energy. This increases the voltage associated with the charge stored in the yarn, enabling the harvesting of electricity. Stretching the coiled twistron yarns 30 times a second generated 250 Watts per kilogram of peak electrical power when normalized to the harvester’s weight.
    Tests showed that a twistron yarn weighing less than a housefly could power a small LED, which lit up each time the yarn was stretched. To show that twistrons can harvest waste thermal energy from the environment, a twistron yarn was connected to a polymer artificial muscle that contracts and expands when heated and cooled. The twistron harvester converted the mechanical energy generated by the polymer muscle to electrical energy. The researchers also sewed twistron harvesters into a shirt. Normal breathing stretched the yarn and generated an electrical signal, demonstrating its potential as a self-powered respiration sensor."
    I have always indicated the need for some battery capacity to be able to receive, store, and release energy at different rates.
  7. May 24, 2019 #7
    7,235
    2,069
    But where would you get the power to stretch the yarn?
    If you want 250W of electricity out of the yarn, you are going to need to put a minimum of 250W of mechanical power into the yarn.
    This is the first law of thermodynamics. It is inviolable.
  8. May 24, 2019 #8
    7,235
    2,069
    Inviolable except for one day each April...
  9. May 24, 2019 #9
    3,965
    1,165
    I am stuck on the long "nanotubes" the rap is these are incredibly strong, perhaps strong enough for the "sky hook" or elevator to orbit.
  10. May 24, 2019 #10
    Sep 18, 2008
    4,948
    2,121
    I am in my '60s and have been reading about all the "revolutionary" engines proposed since the 1950s. The Wankel rotary is one. In fact, AFAIK, it's the only one that ever made it to commercial viablility. All the others were what is known now as vaporware. I call them wishful thinking or investment scams, and don't put any faith at all in such claims until I see it in action, doing actual work and performing as predicted.
    pictsidhe and proppastie like this.
  11. May 24, 2019 #11
    7,235
    2,069
    Many 'revolutionary' engines worked fine. They just failed to create a revolt. The Napier Deltic comes to mind. It lived up to claimed performance and worked very well in service once teething problems had been fixed. But, it never caught on.
  12. May 24, 2019 #12
    Sep 18, 2008
    4,948
    2,121
    If it didn't catch on, there had to be some disadvantages to the design. If there's a better design than the typical V or inline or opposed engine it would take over. Capitalist economics and competition dictates that sort of thing. "Better" would mean, for a given HP output, a lighter, smaller, stronger, longer-lasting, better SFC, and cheaper-to-build engine. Not meeting any one of those factors can doom a design.
  13. May 24, 2019 #13
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
    Going back over the article, it seems that the yarn stretches up to 25%, a question would be..... how much of that stretch would be needed to produce maximum power?
    Would stretch action over 30 cycles per second cause the nano-fibers to break down?
    I'm changing my mind about long twisted bands because that would be a slow cycle. However special design sections of wing spars and longerons might offer the capacitor-like workings they talk about.
    If their hype is anywhere near correct it looks like very good potential. I would think of the possible cam action or air flutter actuation of what could be thousands or even tens of thousands of strands inside structural parts of wing and fuselage of an aircraft.
    Someone has to speculate :cool:
  14. May 25, 2019 #14
    13,092
    5,017
    Is it merely a coincidence that an article about yarn that can be knitted into electricity-generating clothing is published by “Tech BRIEFS”?
    I think not.
    BJC and pictsidhe like this.
  15. May 25, 2019 #15
    7,235
    2,069
    Anything new also has to overcome the inertia of the status quo. Incremental improvements are far easier to accept. Anything radically different is going to be viewed with suspicion by most people. It really doesn't help that many radical inventions aren't viable. Few consumers have the technical acumen to properly assess a new concept, so they stick to what they know. A revolution means significant change. That requires significant motivation.
    I'm currently reading a book about the Rolls Royce Crécy. RR came to the conclusion that for the design to be accepted, they would be best off developing it as marine engine until they had the knowledge and experience for it to be a superlative aero engine. It was another revolution, the jet engine, that actually killed the concept.
  16. May 25, 2019 #16
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
    I did find this link that gives a little better coverage.
    “Although numerous alternative harvesters have been investigated for many decades, no other reported harvester provides such high electrical power or energy output per cycle as ours for stretching rates between a few cycles per second and 600 cycles per second.”
    https://www.utdallas.edu/news/2017/...-Energy-Harvesting-Yarns-Gene_story-wide.html
    600 cycles per second, this speed would work well with airflow somewhere around a plane to activate a flutter condition that would cause the stretching of the "Twistron".
    I'm thinking the most expensive batteries today would be cheap by comparison, but it might work out that all the power needed would come at the expense of a little extra drag.
    Not sure what conditions produced 250 Watts per Kg?
    Just spotted the answer.... 30 cycles
    Maybe someone can make this clear to me......
    Stretching the coiled twistron yarns 30 times a second generated 250 watts per kilogram of peak electrical power when normalized to the harvester’s weight,
  17. May 25, 2019 #17
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
  18. May 25, 2019 #18
    3,965
    1,165
    You forgot "not invented here"
    pictsidhe likes this.
  19. May 26, 2019 #19
    RonL
    RonL
    RonL
    Jan 9, 2007
    460
    29
    Texas
    Looks like Carbon Nanotubes ("Twistron") is a little above my price range. :(
    "A group of researchers from Universiti Sains Malaysia (USM) have successfully created a new method for producing carbon nanotubes. The new method is capable of reducing the price of carbon nanotubes from $100 - $700 US to just $15 to $35 US for each gram, much lower than world market prices.
    The method known as the Continuous Production Method of Carbon Nanotubes using Rotation Reactor is the first ever created in Southeast Asia.
    Carbon nanotubes are widely used in the production of end products such as memory chips, rechargeable batteries, tennis rackets, badminton rackets, bicycles, composite to manufacture cars, airplanes and so forth.
    The research team leader, Assoc. Dr. Abdul Rahman Mohamed said, a new rotation of the reactor system is designed to enable the continuous production of carbon nanotubes without compromising the quality and authenticity.
    "The system is capable of producing up to 1000 grams of carbon nanotubes a day,'' he said.
    He added that the developed system is also environmentally friendly as it operates at atmospheric conditions, cost effective and does not require a large space to operate the reactor."
