EFIS & EIS on tablet split screen.....
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
I've been researching EFIS & EIS on a tablet using split screen but can't seem to find exactly what I'm looking for.
All the systems that I have found seem to be a universal fit for all engines and have several items displayed that I dont need or want on the display and I'm not sure if the displays can be customized.
Here's what I'm looking for.......
1. EFIS : all the usual stuff with the possibility of a moving map included in the display.
I like the Talos system but it doesn't have EIS included.
2. EIS : display for Rotax 670 without the extra stuff that cant be used with this engine.
It's a 2 cylinder 2 stroke...I dont need oil pressure or oil temp..etc.
3. $$$ : we are talking about a program with a transmitting box with me supplying the tablet,there's no reason this should cost $1,000.
If someone knows of a system that i haven't seen will you please point it out......
Kevin
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
There are systems out there that have engine information on one side of the screen and navigation information on the other side of the screen,however,they all seem to be set up for 4 stroke engines and have displayed features that I cannot use so it's a waste of space.
I would like to find a system with the split screen that is set up for a 2 stroke so no other unusable information is cluttering the display.
I may just hard mount an EIS from Grand Rapids Technology in the plane to handle engine monitoring and then use a removable tablet for EFIS/navigation such as the Talos system.
This is an option if I can't find a split screen system set up specifically for a 2 stroke.
7,019
Most of the lower cost solutions for tablet-based EFIS do not include EIS. GRT is a good option and you might also take a look at the MGL Avionics color or black-and-white units that fit standard instrument holes. For a two-stroke you might also consider individual digital instruments like the Trail Tech TTO series...a tach, two CHT, water temp, and voltmeter would only run about $300 total. After that, you could get away with a basic GPS-based tablet EFIS app with navigation and maybe an analog altimeter and ASI.
7,373
I'm actually looking into making affordabe pseudo-analog instruments at the moment for those who want steam gauges but not the weight. Arduinos, stepper motors and needles.
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
I just looked at MGL Avionics and will pass on that......$6,000 is way out of my league.
Trail Tech TTO instruments are made for motorcycles and while they can be adapted for aircraft use.....a Grand Rapids EIS would be much simpler for about the same price.
Thanks for pointing those out......
Kevin
7,019
Actually, I was suggesting the MGL single units as an alternative to the GRT EIS units with a basic monochrome LCD screen, not a $6,000 color touchscreen panel.
COLORB&W
2-1/4"Vega EMS-1 $395Infinity E3 EMS $310
3-1/8"Blaze EMS-2 $455Velocity E-1 $345
These are prices without senders, but then so are the GRT units. The monochrome units are being phased out and replaced by the color units, so they are an especially good deal.
Daleandee
Sep 11, 2015
950
SC
I use the MGL singles along with my iFly (recently upgraded from 720 to 740b) and have more information than was found on the moon landing flights. :gig:
Seriously, I have an MGL for engine info & one for flight information. Sonex is currently showing the pair on their site at $1,085.75. Here's my panel:
FWIW,
Dale
N319WF
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
The MGL gauges are very nice but from what I can tell they are setup for mainly 4 stroke engines.
It doesn't appear that the gauge can be customized by eliminating items from the display that will not be used on a 2 stroke...oil pressure,oil temp......etc.
And they dont seem to have a warning if a pre-set parameter is violated....it looks like the violation is just recorded......I may have read that wrong though.
It's funny that you made the comment about the moon landing....I just watched a program about that last night.
My cellphone that I'm using to post this message has about 1000 times more computing power than their buildings full of computers combined did.
And the way the onboard system was set up in the capsule to input commands is truly simple.....noun and verb inputs to the computer,absolutely amazing.
Kevin
Daleandee
Sep 11, 2015
950
SC
The MGL Engine monitor gives CHT, EGT (2 each) oil temp and pressure (not needed for two stroke) along with RPM, hobbs meter, volt meter, and maintenance timers. I have turned off items I didn't need - don't know if they could be reassigned i.e. OT used for water temp on a Rotax 582. You can set warnings, both high and low for alarms that will appear on the screen and illuminate the red light on the gauge.
You might also consider a Grand Rapids EIS Engine Monitor system - https://www.aircraftspruce.com/catalog/inpages/grt-eis-monitors.php
Dale
N319WF
PS: Those brave test pilots that brought about the discoveries that led to us landing on the moon have some great admiration from me. When I was a young child I wanted to be one of them. Knowing what I know now I believe I'll stand by and watch the real men do their thing.
7,019
I considered that as well, at least for engine instruments, but I think it would be very hard to get it down to a price point even close to the combination of automotive engine gauges and basic flight instruments for the sake of saving a couple of pounds. I also don't have the electronic skills to pull it off, though I have dabbled with Arduino a bit.
For example, I like the Speedhut gauges, which are by no means the cheapest option. A quad 3-3/8" VOLTS/OT/FUEL/OP + a 2-5/8" (2-1/16" hole) 4,000 RPM TACH + a 2-5/8" (2-1/16" hole) 500 °F CHT gauge together all go for about $567 with periodic 20% off sales bringing that down to $454. This is for lighted gauges in your choice of colors, bezels, etc. with all the senders except fuel.
If weight is that much of a concern then you can go digital with a pair of MGL singles that give you almost all your engine *and* flight functions in two 3-1/8" units.
dcstrng
Oct 17, 2010
913
VA or NoDak
Yep, I've played all sorts of "what-if" games and have acquired enough instrumentation for any two VFR birds, but the MGL Flight 2 and E1 probably provide as much or more info than the light-VFR pilot needs for cockpit distractions. When my project is completed in another century or two, or three, that’s what will be in mine – bought them years ago, but they shipped way faster than I build. I may also mount a RLI, since I bought that too some years back… three gauges plus a compass and some way to measure gas should be more than enough in-cockpit entertainment...
spaschke
Oct 24, 2012
236
Denver, CO
Sounds like you should use an android pad or ipad and get involved in one of the open source projects out there on GitHub, sourceforge or http://diyavionics.com. I believe there is one called openEFIS, another diy-efis. They may require some electronics assembly and/or some programming though. You can tailor them to exactly what you want.
openEFIS looks to be what you are looking for. t.
https://www.openflightsolutions.com/coming-soon-flightbox-efis/ looks really good.
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
So I've researched a lot of possibilities with the EFIS & EIS on a tablet......
EFIS ......doesn't seem to be too difficult,there are several options available.
EIS.....this is the one that I'm having difficulty with,there doesn't seem to be anyone offering a setup that will allow you to display engine parameters on a tablet.
There are digital systems out there but they are self contained units such as GRT's model 2000.
While GRT units have been used for years without problems,I've used them myself,they are outdated and in my opinion a bit overpriced for what you are getting now days.
And anything else that I have found by other companies tend to be setup for 4 strokes and have displayed items that will not be used on my Rotax 670.
Here is what I would like to find and hopefully I am overlooking a company that offers just such an item.....
1. EFIS & EIS on a split screen of 1 tablet.
If I need to run 2 tablets side by side,1 for EFIS & 1 for EIS,I could live with that.
2. I will be changing from front seat to back seat at times so I either need a setup that I can move to the back dash or 2 independant systems,1 in front & 1 in back,because I will not be able to access the front dash from the back seat.
Anyone have some advice ?
Kevin
6,765
I could swear I've seen an ad or write-up for some sort of a small black box with a bunch of powerplant sensor inputs that interfaces with a tablet, giving you an EIS on the tablet. I'm not a knowledgeable avionics guy, but I'm sure I remember seeing some kind of gadget for this.
12,263
I would think there would be a way to make a Raspberry Pi or like and it’s signal amplifiers do the job, then talk to the tablet. Stuff is there off the shelf. You just need to make them talk.
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
Unfortunately,with the number of items that need to be completed on my Stork build rivaling a 10 year olds Christmas wish list.... I just don't have the time or energy to put into developing an EIS system so I would much rather just utilize a system that is currently in use.
I wish I had the time & money to develop a custom setup for my plane but it's just not going to happen.....
Kevin
Jay Kempf
Apr 13, 2009
3,805
Warren, VT USA
I really want a little I/O device that can take stick, clamp on CHT sensors and feed it to a tablet type monitor. It would be nice if this existed for any engine application. It would be nice if that came with software and COTS sensors so that full engine monitoring could be piped to a 10" android tablet.
Dreaming....
The EFIS sides seems to be handled quite adequately.
MadProfessor8138
Nov 3, 2015
738
Ekron,Kentucky
That's what has me sort of confused with the whole issue.....
It would seem to me that the EFIS setup would be more difficult to do than the EIS portion....yet,I can't seem to find anything pertaining to the EIS.
Kevin
Latest posts
