Grimace
...so long as it only reaches that speed while climbing and gets the power chopped back when in dead-level flight).
This is referencing an ultralight glider. In a nutshell, any powered UL glider is an "ultralight" and gets lumped in with the 254lb folks). I spent some time rereading Part 103 looking for ideas and came up with this-
Let's assume I had a 40kw e-motor which was capable of blasting past the 55kt limit. So I set the controller to limit power to 25kw in order to stay under the *maintaining level flight* requirement of part 103. Assume this would not be override-able in flight.
But what if I also had a "turbo" button that would allow me access to full power, but only under the following circumstances: Either when AOA is over 5 degrees, or for 2 minutes after a weight-on-wheels switch opens,
This would make it impossible to maintain level flight above 55kts, but it would also allow you to climb like a mf'r and get off the ground in a shorter distance. The FAR does say that artificial means of controlling level speed are ok and it's not really a work-around if it's only allowing access to more power in climb situations.
Hypothetically, sure, I could have a level speed of 55 but be capable of 100kts at a 3° AOA with a 50fpm climb rate. but I'm not even talking about working around the system, I just want to maximize performance within the rules. What do you think?
