Ducted Fan propulsion
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by yankeeclipper, Jun 3, 2009.
  1. Jan 30, 2014 #41
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
  2. Jan 31, 2014 #42
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
  3. Jan 31, 2014 #43
    John.Roo
    John.Roo
    John.Roo
    Oct 8, 2013
    231
    166
    Letohrad / Czech Republic
    Dear Ross,
    just to precede misunderstanding – UL-39 is not my project.
    Robert Theiner is my friend and I like work of his team
    J
    I can see that “ducted fan propulsion system” requests large development team and access to aerodynamic tunnel for precise measurements.
    Far away from my possibilities….
    I really wish to see UL-39 in the air this year.
    Best regards!
    Martin
    henryk and Jan Carlsson like this.
  4. Jan 31, 2014 #44
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
  5. Feb 2, 2014 #45
    Aircar
    Aircar
    Aircar
    Banned
    Feb 20, 2010
    3,567
    367
    Melbourne Australia
    Thanks for the clarification Martin I understand the team approach -it is a very nice development in any case -just downloaded the two papers to read later (and thanks Henryk again.)
  6. Feb 2, 2014 #46
    Xanadrone
    Xanadrone
    Xanadrone
    Nov 24, 2011
    195
    43
    Bucharest Romania
    Outstanding initiative indeed - and one of the few, if not the only truly professional approach in this field (ducted fans for ultralights).
    And a big A+ for Henryk too, who brought us this valuable information.
    I wonder though why a 10-years old variant of the Yamaha R1 engine (slightly detuned from 179 HP/12,500 rpm to 150 HP/10,500 rpm) was preferred instead of more modern motorbike engines.
    Anyway, the positive results of preliminary dynamic tests (175 kgf static thrust - a good value for a 58 cm diameter ducted fan at over 6,000 rpm) show that the usual issues of overheating, seizing etc. are not at all insurmontable.
    P.S. I’m still not convinced that a CLmax. of 2.61 - needed for the 450 kgs MTOW, 8.5 mp wing area and the 65 km/h mandatory stall speed - would be achievable in that (very sleek and aesthetic anyway) L-39 configuration.
  7. Feb 5, 2014 #47
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
  8. Feb 13, 2014 #48
  9. Feb 13, 2014 #49
    Xanadrone
    Xanadrone
    Xanadrone
    Nov 24, 2011
    195
    43
    Bucharest Romania
    Impressive data for a RC-ducted fan, but let's not forget that those 23-24 kgf thrust are obtained with the price of over 15 kWh absorbed (310 Amps at +50 Volts = 14S LiPo) - so, the "usual" ratio of approx. 1 kgf static thrust per e-HP remains the same.
    And there's no need for complex explanations, those RC-ducted-fans being in fact simple cylinders, without any performance enhancement-study involved (maybe just a little bit in designing the fan-blades).
    Your previous L-39 UL example shows the good path to follow - also a more complicated one -, although I still believe that ducted fans remain only a "compromise" sollution for swift homebuilts, especially when the designer doesn't want (or doesn't succeed) to find enough prop-clearance.;)
  10. Feb 28, 2014 #50
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
    http://www.reaa.ru/yabbfiles/Attachments/P2280755__Large_.JPG
    =PJ-II=one step forvard,two steps back...
  11. Mar 4, 2014 #51
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
  12. Mar 7, 2014 #52
    Malish
    Malish
    Malish
    Oct 11, 2013
    480
    786
    Russia. City of Volgograd
    henryk likes this.
  13. Mar 7, 2014 #53
    BoeveP51
    BoeveP51
    BoeveP51
    Jan 25, 2008
    97
    10
    Spring Hill, FL - formerly W. Ossipee, NH
    Just as a note of interest... I found this site yesterday. Interesting developments
    Trek_Aerospace_Home
    Merle
  14. Mar 7, 2014 #54
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
  15. Apr 4, 2014 #55
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,776
    466
    krakow,poland
    rv6ejguy likes this.
  16. Apr 5, 2014 #56
    Floydr92
    Floydr92
    Floydr92
    Aug 13, 2013
    357
    119
    Scotland
    not worth starting a new thread but on the same subject....
    am i missing something here?
    E-flite Delta V electric ducted fan for rc planes -
    69mm fan
    2.8 lbs static thrust
    644w = 0.858hp
    = 3.26lbs static thrust per hp ... seems pretty good to me?
    from what i've read most prop setups would give between 2-2.5lbs static thrust per hp
  17. Apr 5, 2014 #57
    12,466
    2,518
    Props on full scale pull about 5 to 6 pounds per horsepower. ( depends on the airplane and prop, of course)
    A .40 size OS glow fuel model engine is listed at 1.0 hp and will pull 4.5 -5 pounds ( straight up in a hover.)
  18. Apr 5, 2014 #58
    Lucrum
    Lucrum
    Lucrum
    Jun 10, 2008
    956
    189
    Canton, GA
    Disk power loading is a factor that needs to be considered.
  19. Apr 5, 2014 #59
    11,907
    3,407
    In the rc ducted fan world, electric has helps reliability a bunch. The orginal glow DF started running .45s at about 30,000 rpm on hot fuel. 12 lb planes. Reliability was terrible so they started stuffing .91s into the same spot also running crazy rpms but they were down enough to help reliability. When the real jets hit, it transformed the planes. Now you have the same diameter engine but now it could turn 100,000 rpm and it made the planes so much better to fly. The glow planes always felt like they were dragging around even at a 120 mph; the jets just feel like the could "get on step." Glow is pretty much gone in the rc jet world. The electrics can be run close to the turbine rpms for the thrust; the problem is battery lasts about 5 min for an equal turbine like setup. The smaller fans flying the 3 lb foamies fly for a lot longer, but fly 1 min longer than needed, and you cooked a $150 battery.
    BBerson likes this.
  20. Oct 6, 2014 #60
    Steve C
    Steve C
    Steve C
    Oct 6, 2008
    59
    36
    Lodi, CA
    Sounds like you don't really know that much about models. The 91 glow engines turned about 24,000 rpm and some of those had planes going 200 mph. I've seen guys with well tuned motors start them by flipping the starter wand by hand. Reliability had a lot to do with the operator apparently.
    Electrics don't turn the kind of rpm that turbines do. 50k would be a lot for EDF and turbines turn anywhere from 120 to 200,000.
    It will be interesting to see if this UL-39 works out. I've done some work on a similar project I wanted to do. I like motorcycle engines as well, but the clutch and transmission is built in, so I wonder how they will deal with that. There's a BMW twin that comes apart from the transmission, but it doesn't have as much power as the latest superbike engines.
    Steve
