Ducted Fan propulsion
yankeeclipper
Jun 1, 2009
47
Northeast.
Well, since some of you provided such thoughtful feedback on the question of fuel injection, I may as well put this one to you as well:
Why do ducted fan configurations seem to be entirely absent from LSA's and homebuilt's? Without having actually tried constructing such a propulsion system, I wouldn't imagine that cowling the fan with reasonable precision would be exceedingly difficult. Also, the challenges of weight and reliability of the cowling and drive mechanisms should be feasible too, given the indirect-drive configurations of many motorgliders.
The disadvantages that come to mind are potential fan balancing complications, and a drive mechanism that can handle the higher rpm's of ducted fans.
The benefits, aside from efficiency, would be smaller diameters and greater safety (given enclosure).
Just curious, really.
13,495
Hi YC,
If you do a search, you'll find that this has been discussed on this forum in the past. If I recall correctly, I think that the bottom line was that, in addition to being difficult to build a precise, structurally sound duct, a duct may benefit you for a static thrust design such as a hovercraft, but is not as efficient as a well designed unducted propeller for general aircraft use. There is also a distinction between a true ducted fan (with a long duct) versus a shrouded fan with a very short ring around the prop to control tip losses. In the case of hovercrafts, you will find that they use the shrouded fan. Long ducts almost always come with great penalties and very little gain.
Bruce :)
Canuck Bob
Apr 13, 2009
132
Calgary, AB
I once considered this system only briefly. It struck me that there are far too many failure points for catastrophe. It was the close tolerances for proper effect combined with a structure that was safe and didn't restrict the shroud. Way out of my league and tooling capabilities.
lr27
Nov 3, 2007
3,822
Probably it's too finicky, but this guy Goldschmied came up with some neat tricks for simultaneous propulsion and flow control on axisymmetric bodies. Perhaps these could have some application to aircraft. See following URL:
CAFE Foundation & The GAT Challenge
Starman
May 16, 2009
2,011
High in the Andes Mountains
I think the reason that Varieze was too slow is because the drag caused by the prop shroud wasn't put to any use. By putting it to use I mean optimizing the other surfaces to account for the large increase in tail volume added by the duct. For example it probably doesn't need any vertical tails due to the side area of the duct, the rear wing could be made quite a bit smaller due to the added horizontal area (times 2) of the duct, and the landing gear could have been shortened. After doing that sort of thing the plane would probably have about the same overall drag as a standard version.
13,495
Jim Miller had a shroud on his formula racer (aka, Miller Special, Gem & Pushy Galore), but it was later removed and replaced with a small elevator atop the rudder. Not sure why, but might be worth looking into.
Jul 29, 2005
14,112
It wasn't giving him the stability and control that he expected. He changed it to 'conventional' fin and tail (if you can call it that, on his latter airplanes!) to improve the stability and control effectiveness.
djschwartz
Jun 21, 2008
982
Portland, Oregon
It also went faster without the shroud. Several other pushers were built and flown at Reno based on this design. None had ducted props. One was destroyed in a fatal accident when a propeller failure took off the tail. I saw that happen. Very sad.
Starman
May 16, 2009
2,011
Well obviously, they're doing it all wrong :) They're using props and comparing them to props when they could be using fans and comparing them to jets :D
If you, for example, were to take the fan off a modern turbofan engine used for something like a Learjet and power that fan with a 1000 HP engine then you've got the same thrust as a single Lear jet turbofan because they make about 1000 HP (My info could be 20 years outdated) I think you can get better fuel efficiency with a piston engine making 1000HP than a turbojet core doing the same thing.
Soo, with one of those you could go high subsonic in the right plane (hey, I just realized, I'm designing the right plane now =)
But yes, good info, but bad news, about the prop failure taking the tail off, something for me to think about and design for, thanks.
orion
Mar 2, 2003
5,800
Western Washington
In these discussions it is important to discern between a shrouded propeller and a ducted fan. There is a vast difference between these two ideas however the distinction between them tends to be a bit gray. For the purpose of a general discussion a shrouded prop is generally defined as a shroud configuration whose chord is one half the prop diameter long. Furthermore, a shroud provides not only a sealing surface for the prop tips but if shaped properly, it can also produce a surprising amount of thrust, especially near the lower end of the speed spectrum.
A ducted fan on the other hand is generally characterized by an inlet duct, a working section and an exhaust section. Some can be quite short but others are designed to be look-alikes to a jet engine installation, most likely to be buried in a fuselage. This design is configured primarily for the fan but a very slight flow improvement can be gained through proper shaping of the exhaust, although this must be done very carefully since it does tend to be much more a point design than any other alternative.
Ducted fans do have a tendency to have substantial penalties since the small diameter fans do tend to be rather inefficient and the added wetted area of the ducting can introduce sizable friction losses to the whole. The classic design case (back in college) is where the goal is to configure a Cessna 150 type airplane but one that is designed about a ducted fan propulsor. The goal of the exercise is to determine the amount of horsepower needed in order to provide it with identical performance to that of the small Cessna. The answer is always surprising since it turns out that the ducted fan configuration needs almost three times as much horsepower as the conventionally powered Cessna in order to achieve the same speed and climb (although these two values can be traded a bit, one against the other).
And it turns out when you look at power to weight ratios and use the proper scaling factors for the modern RC aircraft, you'll find that the ratios for the small planes do tend to be even higher. But RC engine technology has come far so the specialized two-strokes can deliver the high power levels the scale planes need for the performance. Too bad we can't make reliable two strokes of this size for the big toys - but then that would really suck down the fuel - probably close to that of a more conventional jet.
Starman
May 16, 2009
2,011
I think the high power ducted fan would only be advantageous for going over 400mph since the ability of open props falls drastically at that point.
There are fairly high powered two stokes available. The Kawasaki H2 750cc could put out a lot of power and have done less than eight second quarter miles on a bike. You could chain gang three or four of them together to get 1000hp. It might be good for setting records, but wouldn't go far.
Since were on this subject, has anyone seen any of these Learjet size fans for sale cheap, like maybe one that came off a broken engine? Or say, how much for a broken Lear turbofan engine but with a good fan on it? :)
edit. I think the best way for something like that would be an in fuselage duct that is optimized to slow the air down at the fan and then speed it up at the exhaust.
I wonder if you could add and afterburner to something like that?
orion
Mar 2, 2003
5,800
Western Washington
A few years back there was a company in Florida that was developing a fan type propulsor designed for use in a ducted fan configuration. Their goal was to provide these fans to the market in a way similar to that of propeller manufacturers - each fan had some adjustability so that it could be fitted to a slight variation of application. The pictures I saw looked very impressive in that it looked to be a very professionally designed and built product. But the main problem with these types of things is that these units have to be specifically designed for, something that your average homebuilder is generally incapable of nor I'm sure is willing to pay for. The developer disappeared fairly quickly.
Regarding the recip powered fan with after-burning, that too has been proposed a number of times and I think I recall there was a patent on the thing at one time. Interesting idea but far from practical since the single stage fan will most likely be incapable of producing enough flow and pressure ratio to make that configuration feasible.
Lucrum
Jun 10, 2008
956
Canton, GA
20 - 25 years ago just one blade from a Garrett 731 fan was at least $1,000. There are over 30 blades per fan. I believe they're Titanium.
Something like that is going to be hard to find "cheap" I'm afraid.
Starman
May 16, 2009
2,011
Oh well, too bad, back to the drawing board then. I guess what we need is a rich benefactor to provide the fan and a four rotor wankel and then I'll provide a high subsonic homebuilt that looks like an F16. Step right up folks, cash talks.
Nov 28, 2009
11
Sacramento CA
Hey there Starman-
It happens to be that I acquired 2 Turbofan Blades from a LearJet Engine during my A&P Training Class back a while ago.
THe Idea I have is to recreate these Blades with Carbon FiberGlass making them extremely ridgid and significantly lighter (as opposed to Titanum)--- These donor blades are 12 inches long and could be used to create a Fan with a Disc area of 30-36 inches. (Ideal for the Scale we're talking about)
You wouldn't want 30 of these things... as that would significantly bog down the engine... but 10-12 in my estimation could work nicely with a 500 HP powerplant.( you would also need to have 9-11 stators to straighten this thrust out into a proper air/exit stream...)
This Prototype would be coupled with a 2003-2006 Dodge Viper V-10 Aluminum Engine that Produces 505HP and only wieghs 500pds,( the newer 2008 engines make 600HP but for double the price @ 30K) A chevy Corvette LZ1 may work as well , but depends heavily on its wieght----
Now----- You have to deal with alot more than what I have just laid out with regard to:
Subsonic fan efficiency--
Duct/intake geometry--
Velocity of a MASS of air as opposed to just creating HIGH PRESSURE etc.etc
But that is where I shut my mouth until my Prototype is Finished, tested and pattened, then proven!
Most people will laugh at this Idea, and dismiss what I am talking about as snake oil.. I have done my homework and studied my predecessors mistakes very closely to figure out how to get around the drawbacks they were having.
As you said------ Money is key to speed-- otherwise, the Future will have to work on my time schedule and salary contributions.
Any R&D manufacturers out there can have a part of this action---
Please contact me if you have interest....
A small NDA can give you the physics behind what I am producing so long as the viable information leads to funding for Development.
I look forward to discussing this topic with everyone.... and addressing any questions that may have come up as problems for previous models and prototypes..
Thanks for talking about this topic that has been around for years--- Love seeing that its still alive.
Q
Paulrod
Dec 28, 2011
1
Kansas City MO
Somebody may have covered this in an earler post, and as a newbie I may have missed it, but what's the thinking on, say, about three fan stages, powered by something small and high rpm, like a Wankel rotary? Would it work on something in the LSA class? Reason I ask, is that I saw on an EAA e-pub, an F-22 lookalike, sized down to Euro ultralight, made by Aerosports.gr, in Greece. It's very interesting, but uses a not-too visible pusher prop. It cries out for ducted fan propulsion. They list it at 300 Kg gross, so it wouldn't have to be real powerful. I'm sure you all remember the line from Independence day, "I gotta get me one of these." Anyway, thoughts?
Aircar
Banned
Feb 20, 2010
3,567
Melbourne Australia
I'm not so sure you can just delete three quarters of the fan blades from an existing engine and expect a good result --with a high solidity fan the interaction between blades is fairly significant and the cascade effect determines the camber twist and so on, so that isolating the same blades to absorb less power will likely fall short ( just look at the incredible degree of blade sculpting on recent turbofan engines --like an Arabian scimitar or Kriss --three waves across the span and variations of chord and twist as well -- no doubt all carefully designed to avoid stalling and maximize efficiency )
Although ducted fans are allegedly efficient thrust producers the track record in small aircraft has been abysmal and the large diameter open prop always comes out ahead on performance and other factors -- multi stage ducted fans as proposed will lead to even lower blade loadings and swirl effects etc that should further lower performance and ultimately the energy left in the wake determines how much power is wasted. How many aircraft have flown with both a ducted and open prop optimized for the same condition to give a clear test ? The Ligeti stratos was one that could have been propelled either way but did quite well with a ducted prop (or shrouded propeller given the low blade loading and number of blades ) --a few Wankel powered ducted prop designs --the RFB Sirius, Fanliner,Fantrainer, Optica,Panther replica,Excaliber, etc have briefly appeared but not persisted and the tail end ducted fan with shroud doubling as a tail looks to be the most hopeful (with electric power solving the shafting issue perhaps) and follows up the work of Raspet on the MSU Marvel which is still a good looking airplane and 'modern' although <50years old.
orion
Mar 2, 2003
5,800
Western Washington
We've discussed ducted fan and shrouded prop propulsion here quite a few times so if you use the search function here, that should get you to the appropriate threads.
The classic school example of ducted fan utilization versus a conventional prop reveals that for a particular set of performance goals (similar to your LSA reference), the conventional prop will have a power requirement of about 100 hp, while the ducted fan will need about three times as much. Also, ducted fans tend to be point designs, in other words, they're good at one design speed. Elsewhere they fall pretty far short. There have been numerous attempts over the past twenty or thirty years at developing ducted fans and airframes but even those that made it into the air were pretty marginal.
