Ducted fan aircraft
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by jthunt, Mar 17, 2012.
  1. Dec 4, 2019 #1621
    Lendo
    Lendo
    Lendo
    Feb 7, 2013
    375
    67
    Brisbane
    I love the idea of a Ducted Fan, I've seen some attempts but all seemed to end up less efficient than an open prop, I've never really understood why. I've spoken to one Aeronautical Engineer who is redesigning an aircraft his Dad designed here in Australia some years back, he says it can be done well for specific applications - he should know, but I think there are too many variables.
    George
  2. Dec 4, 2019 #1622
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    =ducted fans are lower surface as open propellers are...
    (greater surface load,lower specific thrust !)
    -EJECTOR duse can help,aspatially at low speed (taxi,climbe...)
    http://www.reaa.ru/yabbfiles/Attachments/hustawka_multiplikatorwidelec_016_001.jpg
  3. Dec 5, 2019 #1623
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,047
    436
    Everywhere USA
    It’s likely because we have been using the wrong sizing on older ducted fans.
    Compare the PJ-2 to other ducted fans and the other fans are far too large for their power.
    The PJ has almost 200hp per small fan. Many other ducted fans have 200hp with a very large fan. Yet the PJ is much faster despite having a very similar power to weight ratio, and probably similar drag.
    It’s very obvious that older ducted fans were using far too large fans.
  4. Dec 5, 2019 #1624
    jbiplane
    jbiplane
    jbiplane
    Jan 29, 2014
    217
    99
    Krasnoyarsk, Russia
    My customer on paramotor testing my 2-stroke 294cc boxer engine in ducted fan. Cannot spread photos without his permission. What trust do you need?
    GeeZee and henryk like this.
  5. Dec 5, 2019 #1625
    6,661
    2,390
    Just a concept at this point, but looking for something comparable to what the same 25 hp engine can do through a full-size prop and redrive but in a smaller package.
  6. Dec 5, 2019 #1626
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    =30 HP (7000 RPM), 70 kG thrust
  7. Dec 7, 2019 #1627
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    =old experiment with tube drag decreasing (tandem mode)
    -single tube=circa 30 deg.
    -tandem=circa 5 deg,
  8. Dec 7, 2019 #1628
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,047
    436
    Everywhere USA
    Awesome Malish!
    That just made my day!
  9. Dec 7, 2019 #1629
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
  10. Dec 8, 2019 #1630
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
  11. Dec 8, 2019 #1631
    Malish
    Malish
    Malish
    Oct 11, 2013
    480
    786
    Russia. City of Volgograd
    New blade - is "master model" made on 3D printer.
    henryk, delta and AdrianS like this.
  12. Dec 8, 2019 #1632
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,047
    436
    Everywhere USA
    Good work Malish!
    If you have any problems with the plastic attachment flange, I have seen people 3d print with metal inserts. You should be able to add an insert to mimic the steel base of your carbon blades.
    Also, I wonder what will happen if you change thickness to allow higher angle of blades before compressor/fan stall. May allow different RPM range if that’s something you are interested in.
  13. Dec 8, 2019 #1633
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
  14. Dec 9, 2019 #1634
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    https://www.dropbox.com/s/ky1z5jc9g3srohq/Dym - zwolnione tempo.mp4?dl=0
    https://www.dropbox.com/s/htftd6ttj1b2emj/Dym.mp4?dl=0
    =auer experiments with CR differentially drived propellers=>25 % thrust gain...
    <10 % weight increase.
    I think,ducted CR should be better, NO stator need ! (see smoke trajectory...)
  15. Dec 9, 2019 #1635
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    2,047
    436
    Everywhere USA
    Very interesting. It appears to be squeezing the exhaust like turbine exhaust squeezes during shock diamonds.
    It’s like a Venturi caused by the different inertia of the air flow and still air. The flow is very fast but surrounded by still air. This pulls the still air inward and squeezes the flowing air into a tight well controlled flow.
    But why this only happens with twin props I do not know. It must be how it affects the center of the flow.
  16. Dec 9, 2019 #1636
    Lendo
    Lendo
    Lendo
    Feb 7, 2013
    375
    67
    Brisbane
    henryk, Good find, the Ligeti -Stratos (ducted-fan) was the one I mentioned previously, his Son is reverse engineering the concept as all documents were lost when he was killed. A modification to the design tested at low altitude, as directed by CASA.
    George
  17. Dec 9, 2019 #1637
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    =this aiflow is focused/concentrated and so powerfull=no possibility to stay in it
    for thrust force read !!!
    (I should read =235 kG=in lying position !)
    https://www.dlr.de/bt/desktopdefault.aspx/tabid-8196/14020_read-35636/
    =CR FAN
    https://slideplayer.com/slide/3853756/13/images/3/Thrust+Augmenting+Ejector.jpg
    =EJECTOR for thrust augmentation...
  18. Dec 11, 2019 #1638
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    =steel core forks can be made from carbon/kevlar composites...
  19. Dec 11, 2019 #1639
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,785
    468
    krakow,poland
    https://innowacjablog.files.wordpress.com/2019/11/flaris229237.pdf
    =polish 5-place jet with BRS (rocket) + 6 ? auter airbags for soft landing !!!
    -another polish patent=dynamic breake for pataschute=allmost ZERO speed landing...
    https://airsafe.pl/
    BTW= iff Vlanding=5 m/s and distance 0.05 we get deceleration
    a=V^2/2s=25/0.1=250 m/s^2 ( circa 25 "G" !!!)
    =for 7 m/s = 50 "G"
