Ducted fan aircraft
Discussion in 'Aircraft Design / Aerodynamics / New Technology' started by jthunt, Mar 17, 2012.
  1. Oct 10, 2018 #1281
    blane.c
    blane.c
    blane.c
    Jun 27, 2015
    2,873
    492
    capital district NY
  2. Oct 11, 2018 #1282
    Malish
    Malish
    Malish
    Oct 11, 2013
    379
    621
    Russia. City of Volgograd
    Just started installation of retractable landing gear on aircraft. Nose gear are installed and also hydraulic power unit.
    All controls of landing gear hydraulic system will be installed in the nose cone, for easy excess and close location to pilot cabin.
    Main L\G will be powered from there too.
  3. Oct 12, 2018 #1283
    Malish
    Malish
    Malish
    Oct 11, 2013
    379
    621
    Today we're installed "emergency gear down" hand pump
    henryk likes this.
  4. Oct 12, 2018 #1284
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,544
    417
    krakow,poland
    =very clever thing!
  5. Oct 12, 2018 #1285
    3,550
    1,527
    Looks good. If the hydraulic system isn't intact (e.g. blown seal somewhere, etc), is there a way to unlock the mains and shake them down, or a wire to pull them overcenter and into the downlock, etc?
  6. Oct 12, 2018 #1286
    Malish
    Malish
    Malish
    Oct 11, 2013
    379
    621
    No way for main gears, they will not lock, same way it's will be on Cessna's or Lancair IV aircraft. This is problem with main landing gear go into back of fuselage and they will not go to overcenter against airflow, if no hydraulic fluid left for "hand pump".
  7. Oct 12, 2018 #1287
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,596
    326
    Everywhere USA
    Since its a ducted fan and doesnt have a prop to strike against the ground, he could technically just get away with some skid pads.
    Some aluminum "knee pads" right where the aircraft makes contact with the ground when its gear up. Just riveted or epoxied on.
    This way the fuselage wouldn't be making direct contact and the pads would take the scraping instead of the expensive composite fuselage.
  8. Oct 12, 2018 #1288
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,544
    417
    krakow,poland
    =big problem with dust in air inlets...
    =NO upper inlets!
    http://www.reaa.ru/yabbfiles/Attachments/130KM3YG5P-46460__Large_.JPG
  9. Oct 12, 2018 #1289
    rv6ejguy
    rv6ejguy
    rv6ejguy
    Jun 26, 2012
    3,546
    2,570
    Calgary, Alberta, Canada
    Some aircraft used a compressed gas cylinder teed into the hydraulic line with a valve. You could remote mount the bottle, freeing up some space near your feet and it works even if there is no fluid left. Maybe something to consider for production models.
  10. Oct 12, 2018 #1290
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,596
    326
    Everywhere USA
  11. Oct 13, 2018 #1291
    3,550
    1,527
    The T-37 had a setup like that, something like 3000 psi in a small "blowdown bottle." One shot.
  12. Oct 13, 2018 #1292
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,544
    417
    krakow,poland
    rv6ejguy likes this.
  13. Oct 13, 2018 #1293
    3,550
    1,527
    Seems like a good weight for this. I would think 1.1 liters at 4500 psi should be enough, unless there's a massive leak. I suppose a check valve would be needed to assure the air goes only to the gear cylinders, not to the hydraulic pump. This approach might be lighter and more likely to work than the hand pump if the fluid leaks out, but would require more work and possible damaged parts to test it. High adventure!
  14. Oct 13, 2018 #1294
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,544
    417
    krakow,poland
    Vigilant1 and Doggzilla like this.
  15. Oct 18, 2018 #1295
    Malish
    Malish
    Malish
    Oct 11, 2013
    379
    621
    Main landing gear on this aircraft, still be somewhat intruded in air stream, we didn't want to cut main structure of airframe. To do this, we did restrict travel of landing gear legs in retracted position, by installation of extra support(it's can be seen on photo). This is only for prototype aircraft, next aircraft mains will be fully enclosed.
    Front gear is fully retractable into nose cone and have wheel well doors.
    We're know, that this prototype aircraft will lose some performance in cruise speeds, but doing this, we will save time and money to certify this aircraft with new landing gear.
    PA121737 (Large).jpg PA121738 (Large).jpg P7270177 (Large) (Large).jpg P7270214 (Large) (Large).jpg
  16. Oct 18, 2018 #1296
    3,550
    1,527
    Very nice. Unrelated: I've always appreciated aircraft designed to minimize damage in the event of a gear-up landing. The A-10 and some other airplanes leave the retracted wheels down a little below the main airframe, covered by gear doors with a small blister. In the event of a gear-up landing, with a little luck the gear doors scrub through and the tire touches the ground before anything else and begins rolling, and the only significant damage is to the gear doors (and the pilot's pride--and insurance rates). "Those who have and those who will . . ."
    henryk likes this.
  17. Oct 18, 2018 #1297
    Doggzilla
    Doggzilla
    Doggzilla
    Jun 2, 2013
    1,596
    326
    Everywhere USA
    Yes, its extremely important to protect the fuselage from belly landings, even if its just some aluminum skid plates glued to the most vulnerable part of the belly.
    A few pounds of sacrificial aluminum or steel could save a lot of expensive work if there is ever a belly landing.
  18. Nov 1, 2018 #1298
    Malish
    Malish
    Malish
    Oct 11, 2013
    379
    621
    Installation of retracts almost done.
    mcrae0104, rv6ejguy and henryk like this.
  19. Nov 1, 2018 #1299
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,544
    417
    krakow,poland
  20. Nov 1, 2018 #1300
    Malish
    Malish
    Malish
    Oct 11, 2013
    379
    621
    No problem with that, "large engine(LS6)" - a lat of heat! Cabin heater working wonderful - in the winter we can fly in T - shorts!
    henryk likes this.
