Drill Size For Dimpled -4 Rivet Holes
GESchwarz
Oct 23, 2007
1,222
I've noticed the after dimpling a #30 hole, the the diameter of the hole opens up, making for a loose fit for the -4 rivet.
Should I drill thes holes with a 1/8" or #31 or #32 drill so as to have a tighter hole and stronger attachment?
Captain_John
Feb 3, 2003
699
KPYM
Gary,
Nope... you are doing things right.
That is normal.
What I often do is crisp things up a bit by just touching the deburring tool to the interior portion of the dimple.
It really makes for a flush, smooth product.
:) CJ
LArzfromarz
Aug 17, 2009
95
Sunny Central FL
The metal stretches when dimpled so it will open up.
Just curious-
What application calls for dimpling before riveting?
I'm a "certified" guy and haven't seen this before.
Larry
MadRocketScientist
May 16, 2009
1,749
My whole aircraft is 0.020" and 0.016" so I have a few dimples to do as I am flush riveting the whole thing.
I have heard of people using a microstop countersink to make the dimpled holes fit the rivets even better. Just don't remove any more the smallest amount of material.
Shannon.
heytwo
Sep 30, 2009
5
Arizona
10-4!
I'm just used to .032 maybe .028.
Larz
Its not "structural" to use 3/32 AD rivets in .032 .
You must use a "ratio" of rivet diameter to skin thickness.
You cant simply increase the number of rivets .
I will do some wing spars with .080 , it can use 5/32 AD's
or 3/16 ..but not 1/8" AD's .
In the late 60's , i did some stretched
Beachcraft , tri-pacers in Tucson and they ordered me to
use 1/8 AD's in 5 layers of .032 2024-T3 . BAD !
I did Hot dimpling in .032 , maintains the 60,000 PSI
UTS of the metal . Alum' was forced around a 1/8"
pilot , made a perfect .128" rivet fit
Use tiniest cable , about 3 inches long .
push both ends into a 1/4" steel tube , smash tube .
Chuck it in 3/8' drillmotor to deburr
aircraft skins .
Where can i get 2024-T3 ? Wing spars .
Clecos cheap ?
Edwards AFB . A-11 with green tires , laboring to
get off .. The very first BlackBird .
Rocket test sled at over 4000 MPH ..
Vaporized Aluminum ! I saw the booster out of
my R eye ,and the cloud of dust from my L eye and
of cource the boom , breaking the sound barrier .
No water to slow it , it was just to waste
the left behind equip , that was not sent to new sled
facility in NM .
Then the time i raised a AGE cart tongue too fast
and dented a B-58 Hustler elevon ..Ouch honeycomb .
