Wanted Dragonfly MK2 or MK2H MAIN GEAR
dwalker
Mar 6, 2021
150
Like the title says, I want to be able to convert my Dragonfly from tri-gear to taildragger, and to do that I need the Dragonfly MK2 gear, either the mid-wing stub gear or the hoop gear will work, with the hoop gear being preferred. I know of at least one owner that has used KR2 main gear as well, so possibly those would work as well.
Deuelly
Nov 6, 2012
281
Marshall, MN
I'd like to covert my tri-gear to taildragger. Have you been able to find any drawings or pictures of the hoop taildragger install?
dwalker
Mar 6, 2021
150
In the newsletters there are articles about the various landing gears and attachment methods.
Deuelly
Nov 6, 2012
281
Marshall, MN
That's what I was afraid. All the hoop gear attachment methods in the newsletters are pretty crude and not well documented. I was hoping someone had actually drawn up plans like they did for the tricycle gear. Its probably easiest to just roll my own.
Brandon
dwalker
Mar 6, 2021
150
Brandon
I can take better pictures of how mine is mounted
Slars
Oct 26, 2014
36
Carlisle, PA / USA
I have a set of MK2 gear legs that I will not be using. If you want them, they can be had for the cost of shipping. They originally had the HAPI brakes and wheels on them, but the HAPI stuff is junk.
If anyone has any photos of a MK3 nose gear mounting, I would appreciate a photo or two.
dwalker
Mar 6, 2021
150
I'll pm you!
My nose gear mount is integrated into the engine mount. I'll send you pictures this afternoon. The engine mount is I believe for a VW, and I intend on going Corvair, so the mount may be up for sale soon.
