The other thread was about Acrylic sheeting
Acrylic sheeting
I'm pondering draping coroplast over a hot sheet metal mould. The mould is a 8x4 sheet of thin metal, heated likely with steam. The mould only needs a few wooden ribs to get it's shape. Hopefully, i can reuse a metal sheet several times. leading edges are going to be single use. Gravity drapes the coroplast over it. Coroplast ribs, maybe cut with CNC, it wouldn't need many as the coro skin would be pretty stiff anyway. I've never built an airplane, but have built many other things. Low parts count and simple shapes really, really speeds things up. Moulding the coro is the current big hurdle. if I build a CNC, the ribs will takes seconds to cut, as will ply ribs for the wingskin moulds. plan B on moulding the skins is to get UV resistant black correx, drape over metal again, but heat the coro with infra red lamps. Plan C is to build a giant oven, might be simplest, though bulky and my paranoid side is telling me to do that outdoors... Over in Europe, foamed concrete blocks are a big thing and would be ideal. They can be stacked dry. Over here, I'd likely have line a wooden box with fibreglass batts.
Coroplast can be glued a few ways, but you do need special glues. There are a couple of hot glues that work well. I'd favour these where it's possible to use them as you get full strength in seconds. Some fairly simple gluing jigs from straight bits of wood should produce a useable wing. There are a couple of CA adhesives that work too. Might be needed when I can't get a glue gun to the joint. Coroplast has the surface activated by corona discharge. This really helps stuff like CA glue and paint stick. My current crop of Coroplast is a year old and the treatment has likely dissipated, but they'll do for moulding tests.
4mm coroplast is 0.143lb/sqft. For a 150sqft wing, that'd be around 45lb of skin. Not too hideous as it's won't need half as much support as fabric. 5mm is .204lb/sqft, 6mm is 0.284 lb/sqft, getting a bit heavy for sheeting the whole thing, but might be good on leading edges.
For hinges, I was thinking of squishing the coro flat for the hinge section with a suitably weighted bar when it is being draped, the stuff has some impressive fatigue properties
This thread is a inspiring as it's about model airplane tech being used for a man carrier.
