Hello All,
All good points and I have explored all of them already. I have multiple widget designs I have tried in CAD. The one I showed was the one that looks most promising. Making it out 6061 ends up being much heavier than the orriginal. More than 2X. The hybrind one I showed above is only a few grams different.
Here is the problem I am trying to solve. Rivet Gun access is too tight and yes it may have worked for a long time, but i imagine its a pain in the ass to bend the flange enough to get the gun in when installing. Why not just fix the issue now if I can. Also I dont have the widget tooling and single source is an issue. Another is, the guy who has to tooling supplying the widgets makes more than I do selling widgets over the plans, and I am the one holding the bag for all the questions to builders. Unsure why Ed woudl have sold the tooling since its an odd thing to part out to someone else, but sadly that is what he did.
Here are the issues and a few other designs I had.
The above show why its worth it to raise the flange a bit. However if I do it in full CNC aluminum or welded they weigh too much in relation to the originals. I am trying to not add weight or make it as negligible as possible.
Here was my first CNC version: 17.25 Grams by comparison plastic original Zytel Verison is: 9 Grams so below is nearly double.
Simple easy to make all 6061 version: 13 Grams.
I don't like that the thin edge profile on the tube interface and feel it could vibrate and grind a groove in the spar tube over time. This reason is why I went to a hybrid design that had the soft flanged surface contacting the tube yet still had a metal connection with the tabs.
I suppose rubber press forming a tall flanged version in 5052-H32 or 6061-T4 or T0 is worth a try as well. I intended to 3D print a drill jig to drill the holes in the curved surface at the correct locations. Also a slide on jig to drill the spar tube holes in the correct location and it can be slid down one location and drilled one at a time.
In regards to 3D printing the widgets, they actually print fairly fast and I can set the printer to print many at a time overnight and in 2 days have one wing worth. I am using an Ender 5 and ender 5+ that I modified to print nylon. Anyone looking to print GF Nylon can PM me for the info.
Take care,
Marc
Take care,
Marc
