Direct drive SBC
Discussion in 'Chevy' started by Natty Bumpo, Oct 24, 2011.
  1. Jul 4, 2014 #941
    Jeffd
    Jeffd
    Jeffd
    Dec 15, 2011
    114
    102
    Overland Park, Kansas USA
    Some real world facts:
    The V8 in the Legend delivered at least 500 hp to a 90" diameter 125 lb Hartzell CS prop. (2:1 re-drive ratio, 4500 max crankshaft rpm).
    I flew the V8 Legend some 250 hrs or so, full power every take-off ( I estimate 250+ take-offs), plenty of full power climbs to 18,000 ft, lots of aerobatics and high G maneuvering, some time on the Reno pylon course, CAFE Foundation evaluation, including multiple top speed runs, etc.
    Never a problem or complaint from the Geschwender re-drive.
    Jeff Ackland
    Altitude Group LLC
    About The Radial Rocket
    MARCVINI and rv6ejguy like this.
  2. Jul 4, 2014 #942
    Autodidact
    Autodidact
    Autodidact
    Oct 21, 2009
    4,513
    799
    Oklahoma
    Yay, the EPI-ENG site is back up! And, I'll admit that that he does paint a less optimistic than possible picture of hy-vo chain drives, for example,
    That's pretty dismal sounding, for sure.
    But he did say "using Morse engineering data". The Morse company would probably rate it's chain as conservatively as it could; it's just good enginneering CYA, and results in a better than predicted durability and as a result, a better reputation for the product. EPI also says that under that scenario, a 3" wide chain would have "reasonable life expectancy", and if the chain is rated very conservatively then it could be that in actual use the 2.5" will handle what the 3" is rated for. So, the point goes to the experimenters - at least to some extent - since we're talking about results that have not been strictly quantified by the kind of testing that a large corporation can afford to do. In other words, how far beyond the factory rating of the chain can you go without a "run it and see if it breaks" process? Every machine has it's breaking point, and that doesn't make it a bad machine. Racing is a more harsh use than full power climbs and aerobatics and may have stressed that engine/gearbox combination too far; this can cause engine failure or PSRU failure either one, depending on which is the weak link, and could be due to the type of crank coupling. Racing is a different animal than sport flying. Marc, if the Geschwender PSRU was adequate for racing, then why was it changed? The fact that Sweet Dreams just unofficially broke three FAI records (which are under review by the FAI) does seem to suggest that the EPI guy (now, what is his name, I wonder?) is a good engineer, and does good design work.
    In my post on transmissibility, I also mentioned that the principle could be found in text books on torsional vibration, and that is why I felt comfortable making the post, because I didn't have to rely on the EPI website alone as my source for information. I wanted to make the point that there are some assumptions that can be made about torsional vibration, and the way engines operate, so that a good system can be designed from scratch that, by the principles of its conception, excludes most of the bad possibilities, and doesn't require the kind of calculation that is difficult to do.
    There is no reason to denigrate the work of an obviously competent engineer. The results had with the GP-5 put EPI ENG squarely in the same realm of "proveability" that Stol, and others who have had tangible success are in. I think that this "experimenters against engineers" thing that seems to come up occasionally is unproductive. And I'm not an engineer! If anyone should resent them, it's me. I do love machines, though, and they have always been made a little bit better by the work of engineers, such as Harry Ricardo, who applied mathematics and theory to combustion chamber design in the early days and improved the power and efficiency over what empiricists had been able to do. And how can you have a good turbocharger without someone who can do the calculations to design an efficient impeller?
    The EPI site is an example of generosity, with lots of good information provided for free, and a list of books to read much like what we have here on HBA. And I don't think he is dragging the rest of us down, or that he has nothing valuable to contribute, on the contrary.
    That,
    , otherwise why would he post up such a large amount of purely technical, and very helpful data? It goes far beyond the typical sales spiel.
    And that's how I've always thought of you; looking on your web site and seeing the modifications you made to the belt PSRU, and the cooling system, and the engine, and nearly every aspect of the engine/installation, I thought "that's what engineers do".
    rv6ejguy likes this.
  3. Jul 5, 2014 #943
    Autodidact
    Autodidact
    Autodidact
    Oct 21, 2009
    4,513
    799
    Oklahoma
    And the saga continues. What a massive thread!:) I wonder if Natty ever follows this still?
  4. Jul 5, 2014 #944
    Brian Clayton
    Brian Clayton
    Brian Clayton
    Dec 7, 2012
    1,042
    530
    Ivey, Ga and Centerville,Tn
    63 pages on discussion of "how to bolt a prop on a SBC for direct drive". I didnt really think it was going to be that hard...
  5. Jul 5, 2014 #945
    MARCVINI
    MARCVINI
    MARCVINI
    Apr 16, 2014
    295
    12
    Pitanga/Paraná/Brazil
    This Aero V8 thing is bigger than life, my friend, and it, for sure, sparkles passionate opinions wherever it is talked about.
    You can be sure that, regardless of each others diferences, something great will come up.
    Marcvini
  6. Jul 9, 2014 #946
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,111
    314
    Northern Illinois
    While we're on direct drive. I found someone who's turning more than 4500rpm direct drive. And a 46" prop.
    EAA - EAA Experimenter - Aeromorph 75
    Not only is it a heavily modified engine, it's also turning "crazy" rpm.
    akwrencher and Brian Clayton like this.
  7. Jul 9, 2014 #947
    Brian Clayton
    Brian Clayton
    Brian Clayton
    Dec 7, 2012
    1,042
    530
    Thats pretty neat. I like outside the box thinkers....
  8. Jul 9, 2014 #948
    stol
    stol
    stol
    Feb 15, 2008
    497
    145
    Jackson Hole Wyoming
    Agreed...... And I bet it was ALOT of work too.....
    Also.... 4500 rpm's with a 46" diameter prop = still within reason.....
  9. Jul 10, 2014 #949
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,568
    3,407
    Mojave, Ca
    I'll imagine that the piston speed (even at 4600 RPM) is well under that of a typical Lycoming.
  10. Jul 10, 2014 #950
    PTAirco
    PTAirco
    PTAirco
    Sep 21, 2003
    3,501
    1,013
    Corona CA
    Tip speed on that prop is about Mach 0.803 at that speed. Quite reasonable, if not ideal.
  11. Jul 10, 2014 #951
    Toobuilder
    Toobuilder
    Toobuilder
    Jan 20, 2010
    4,568
    3,407
    Mojave, Ca
    Concerning piston speed - the little VW based engine has 27 FPS @ 4500 RPM compared to the 32 FPS of a Lycoming 360 @ 2700. To match the piston speed, the Lyc would have to pull back to about 2250 RPM.
    And to tie to this thread a SBC @ 3300 and a LS-3 @ 3200 match the piston speed of a 360/540 @ 2700
    Considering piston speed is one of the main limiting factors on reciprocating engines, its a good illustration why short stroke engines seem to be screaming their guts out, but survive just fine.
    Brian Clayton likes this.
  12. Jul 10, 2014 #952
    crytes
    crytes
    crytes
    May 16, 2014
    140
    12
    Clarksville, TN / USA
    So is there a rule of thumb for maximum piston speed? With the SBC parts availability you can order cranks with all kinds of strokes and tailor an engine you build to the piston speed and revolutions you want. I personally like the idea of going for maximum stroke to squeeze out more displacement but this increases piston speed unless you reduce engine speed.
  13. Jul 11, 2014 #953
    10,237
    6,963
    OK for a slow-moving airplane.
  14. Jul 12, 2014 #954
    nerobro
    nerobro
    nerobro
    Nov 6, 2011
    1,111
    314
    Northern Illinois
    Is 180mph slow?
  15. Jul 12, 2014 #955
    10,237
    6,963
    No, it isn't. My grasp of the facts in this case was slow. :ermm:
    Although at 60 F, 4700 RPM and 170 MPH, I get 0.88 Mach for the tip.
  16. Jul 12, 2014 #956
    stol
    stol
    stol
    Feb 15, 2008
    497
    145
    Still a reasonable tip speed number....IMHO...
  17. Jul 12, 2014 #957
    henryk
    henryk
    henryk
    Mar 8, 2010
    4,864
    482
    krakow,poland
  18. Jul 13, 2014 #958
    Friday I went over to a friends house to see if I could help solve a problem on a truck belonging to another friend of his. The truck was a 58 Chevy with a high $$$$ build up. The original builder had been asking $85K for the truck and ended up trading it to my friends friend. I was scared to touch anything on this flawless black beauty. The paint on the" frame "was nicer than anything I own. The point here is that it was basically a money is no object build, so they didn't cut corners on anything to save a few bucks. The engine was an LS2. The intake consisted of an electronic throttle body......with the MAF sensor fastened DIRECTLY to it, and a small rectangular air filter DIRECTLY in front of that. I know GM recommends at least a 10" straight length of tubing for the MAF sensor to work properly, but this setup worked just fine......over the full rpm spectrum. No driveability problems at all. Since the trucks useful rpm range is wider than the expected rpm range on a DDV8, I would think it
    would pose no problems. I'm not sure if the setup came from "Street and Performance" in Mena AR or not, but thats at least where the air filter was from, and they are experts in adapting LS engines. I wish I had gotten a picture of the setup, but I failed to do so. Anyway, if the use of an elongated intake system is holding you back from considering the LS engine, then this is at least a little more food for thought.
  19. Jul 17, 2014 #959
    Got to see the truck again, so took some pictures this time. Here is what the MAF and throttlebody setup look like. IMGP0872.jpg IMGP0871.jpg IMGP0899.jpg IMGP0897.jpg
  20. Jul 17, 2014 #960
    MARCVINI
    MARCVINI
    MARCVINI
    Apr 16, 2014
    295
    12
    :smile:!!!
    Marcvini
